Sponsored by: CARiD
ses light how do i reset it
Old Jan 19, 2006 | 07:04 PM
z71hsv's Avatar
Unhappy ses light how do i reset it
SES light has come on and i also went to autozone to have a test done and was told it was the kknock sensor.................well further studying has informed me that it could be gas , a gas cap. or wet electrical system ,,,,being that i recently went mudding then washed the truck.....how might I reset the ses light to go off?
Old Jan 19, 2006 | 07:29 PM
SSTYCOON's Avatar
fit the problem, then it'll go off!
that guy at the part store sounds dumb...........gas cap??
there are a few codes for the knock sensor, which one , front or rear ?, low volts etc.....
oh what kind of truck do you have?
Old Jan 19, 2006 | 08:05 PM
T$sMechamT/A's Avatar
is there not any way to reset the ses without fixing the problem? disconnect battery? pull fuse?
Old Jan 19, 2006 | 08:08 PM
273sunsetZ's Avatar
When my ses light came on, I just went up to auto zone and waited till they were extremely busy, around 5 or 6 oclock. Then asked if I could take there OBD II scanner out to my car since they were busy cause I'm kinda in a hurry. He said sure and made me leave my liscense. I just went out to my car plugged it up, and erased the code. Their not allowed to do it, because they can get fined lots of money if they delete a code and something goes terribly wrong with the car. So mabie if you ask them if you could delete it, they might let you.
Old Jan 20, 2006 | 06:54 AM
z71hsv's Avatar
Default ses light
well the owners manual on my 2000 chevy silverado z71 says it could very well be bad gas ,gas cap , wet wiring.....or the codes for right knock sensor ...yes low volt/ circuit
Old Jan 23, 2006 | 01:39 PM
z71hsv's Avatar
Default ses light problems
well i diconnected the battery and it went out ...........BUT ! !!!! ,,,,,it keeps coming back on....... and when it does i sware it sounds sorta like the radiator fan is running faster or something and i have less horsepower ,,,,,it feels this way just a bit.....but if I reset the ses light by disconnecting the battery and reconnecting it it seems to all be fine until it comes back on.......is there anyone out there that really knows something about the 2000 chevy z71 silverado that can tell me how to fix this problem?
https://ls1tech.com/forums/misc.php?...0&forumid=102#
MAD
Old Jan 23, 2006 | 10:20 PM
slowpoke96z28's Avatar
is this thread serious!!?! of course if you erase the code but don't fix the problem the SES light will be commanded on by the PCM. and each time you turn off the SES light with a scan tool, the defect still gets logged as a history DTC. BTW a gas cap can cause a SES light if the PCM detects that it isn't on tight.
Old Jan 23, 2006 | 11:12 PM
Flawless02SS's Avatar
This is now you can reset it. Turn your switch to the "on" position. Dont start the car. In the fuse panel under the hood pull the PCM BAT and PCM IGN fuses. Wait 5-7 min. Turn switch off and then replace fuses and then start car, light shuold go out.
