Sponsored by: CARiD
Problem with car after battery being dead
Old Jan 21, 2006 | 12:21 PM
The PAT WS6's Avatar
Default Problem with car after battery being dead
last night i was lowering my car with DMS springs and i left the radio on for a couple of hours maybe 4 or 5. So i leave the car in the garage over nigth and come back in the mornin to start the car and the battery is dead so we jump start it and not the car is running like **** it will ideal but if you rev it and it comes back down to ideal and studders and wants to die, wtf? i cant figure it out the battery has volts and ****. did the alternator take a ****?
any help would be great
thanks
Old Jan 21, 2006 | 12:26 PM
RPM WS6's Avatar
LS1Tech Administrator
Community Influencer
It takes the PCM some time to relearn the idle after power is disrupted. Usually some driving and idling time, plus a restart or two.
There is also an idle relearn proceedure you can perform. Basically, all you have to do is let the car get up to normal operating temps, then let it idle for 5 mins with the A/C off, and 5 with the A/C on. Then shut it off for 10-15 seconds and restart. Auto trans has a couple more steps (in gear/in park) but that's all there is for an M6.
Old Jan 21, 2006 | 12:56 PM
EDS01SS's Avatar
yeah what RPM said
Old Jan 21, 2006 | 01:59 PM
exactly is works now thanks
Old Jan 21, 2006 | 02:22 PM
RPM WS6's Avatar
Thumbs up
Glad to hear it's fixed.
Old Jan 23, 2006 | 02:11 AM
RedLS1Iroc's Avatar
i had the same problem about a week ago. glad you got it fixd
Old Jan 23, 2006 | 02:48 PM
Super Speed's Avatar
Same problem here a while back too I kinda just let it run shut it off and it did it again and I let it run guess I found the solution! Should be a sticky!
Old Jan 23, 2006 | 11:27 PM
Flawless02SS's Avatar
My car is a weekend driver and sometimes when it sits for 2 weeks and mine does that. I just let it idle for like 10 min and finally she learns all over again.
