Sponsored by: CARiD
Temp ?
Old Jan 23, 2006 | 10:42 PM
DarkhorSe_SS's Avatar
Question Temp ?
What is the normal temperature that my SS(2000) should be running at? I'm curious what ya guys temp runs at. My gauge always shows between 200 & 210. Is this normal or do I need to replace anything?
Old Jan 23, 2006 | 10:58 PM
Flawless02SS's Avatar
Nothing wrong with it, 99-02 gauges are on a single circuit. The only year with a correct working water temp hand is the 98 cars, its dual circuit. Our's will read 210 degrees when temp is between something like 205-230. Yeah, not worth a ****. It will be well worth it buying a water temp gauge for the 99-02 cars.
Old Jan 24, 2006 | 08:13 AM
Weezzer's Avatar
It reads 210 for the actual temperature range of 180-226 degrees.
At least thats my understanding.
Old Jan 24, 2006 | 09:10 AM
LS69TA's Avatar
Yea. It'll always show 210. I'm getting an Autometer temp. gauge to see where mine is actually running.
Old Jan 24, 2006 | 05:07 PM
RPM WS6's Avatar
LS1Tech Administrator
Community Influencer
As said above, for an '00 car don't even pay much attention to that gage. You need a scanner to see the real running temps, or just do an aftermarket gage.
Old Jan 24, 2006 | 09:26 PM
Yeah it was 180-226, thanks Weezzer.......I got too many #'s in my head as it is! LOL
Old Jan 27, 2006 | 05:07 AM
wdtiger's Avatar
Ok, this has been the best explanation of the dummy gauge so far. My only remaining question now is, when it's warming up, is the gauge just simulating warm up or what?
Also, i don't really want to add aftermarket gauges in my car, is there any way to make the dash gauge work properly?
Old Feb 3, 2006 | 08:32 PM
wdtiger's Avatar
Nothing?
Old Feb 4, 2006 | 03:59 AM
Weezzer's Avatar
I installed aftermarket gauges and they pretty much mirror each other untill the true gauge stops approx. 180 while the dash temp goes to 210.
The dash gauge operates from a serial relay from the onboard computer. Its designed to act not unlike an idiot light.
I don't know a way to "fix" it, only to add an aftermarket temp probe into the head above the # 8 spark plug .
Old Feb 4, 2006 | 10:52 AM
RPM WS6's Avatar
Yeah, buy a '98. LOL.....
I've heard of a couple people trying to make the '99+ gage work, not sure if they were ever sucessful, I think most people just go the aftermarket route because it's less hassle.
Old Feb 4, 2006 | 11:12 AM
LS69TA's Avatar
There's a plug above the starter that you can use as well for the sending unit. Or so I was told. But you suppsedly loose alot more coolant by doing it that way. I'm still waiting for my dang gauge to arrive.
Old Feb 4, 2006 | 06:47 PM
wdtiger's Avatar
Interesting, thanks for the info, guys! Only thing i've got to wonder about is, "why?" What did GM gain by ghetto riggin' the temp gage like that. I can only think money, but c'mon... how much could they have saved by doing that? lol.
Old Feb 4, 2006 | 07:15 PM
RPM WS6's Avatar
I've read that it's because people would bring the cars in a lot for overheating problems that they 'thought' were occuring because the temp would climb so much when idling through heavy traffic. So they used a system that did not have any flucuation in the ~175-230*F range. Seems odd though, usually people that buy cars like these would fully understand why the needle is moving and rather have it that way, but I guess GM was trying to avoid warranty claims on non-exisitant problems.....
By Brett Foote | 2026-06-04 05:00:17
