GM Top End Cleaner?
I have always poured it in the oil filler right when I was about to change oil. Just let it run with the whole bottle in there for a few minutes and when you drain it through the drain it will be all chunky and extra nasty. But do it when you change the oil. Don't leave it in there!
1. get the engine up to full operating temperature.
2. disconnect the brake booster hose at the brake booster.
3. slowly start to pour the gm top end engine cleaner into the hose.
4. the engine might want to die, so it would be good to have someone else keep the rpms up a bit.
5. once the container is empty, let the engine die.
6. connect the brake booster hose back to the brake booster.
7. after 10 minutes, start the car. if it doesnt start the first time, just try again. it will eventually.
8. enjoy the smoke show out of the exhaust.
if any of this is wrong, please correct me.
Well, most say you don't have to but I ran some Seafoam through and now I have a slight miss and my MPG took a big ****. I'm doing plugs and O2 sensors really soon. It could be, however, just a freak coincidence.
Top end cleaner cleans out the INTAKE MANIFOLD/Head ports, not the crankcase/valvetrain. If there is some junk stuck on the bottom of my oil pan, i'd rather it stay stuck there. If it hasnt broken loose in all the rhomping i do, i think it'll be alright.
Alot of people on here swear up and down about the wonders of Sea-Foam. You can buy sea foam from most autoparts stores, and use it just like GM top end cleaner.
Be prepared to have MASSIVE amounts of smoke. Think Discount Tire burning to the ground amounts of smoke.
A plug change after the cleaning is always a good idea. Lord knows what kind of gunk will be flowing down the pipes.
One of my buddies had done it to his Tahoe just before I drove by his house. All I saw was him standing infront of it and an ENORMOUS cloud of smoke pouring out the tailpipe. First thought was WTF has he torn up now
? I wouldn't worry too much, like I said it very well could be a coincidence.
(WARNING If you are not carful and allow too much of the top engine cleaner to flow into the engine you can cause engine damage!!
One tech that I know of got fired for this!!
Hope this helps.
I like the chrysler fuel system cleaning kit it comes with a bottle for the gas tank, a bottle for pouring into the injector flushing canister, and a spray can that is like the top engine cleaner that you spray into the throttle body. I had some good results with it at the dodge dealership when i worked there.
Jason
