Werid Electrical Problem
When I started my car to leave a party tonight, the car wouldn't idle. I had to keep my foot on the gas to keep it from dieing. I took off down the road, and all the lights and the motor shut off for about 2 seconds, and then came back on. After it came back on, All the warning lights on the dash stayed on. Then about 2 more miles down the road it did it again, only the service engine light(not the service engine soon light) and the ABS inop light stayed on until I got home. When I pulled into the driveway, the car was hunting for the idle until I shut it off. All the guages read normal all the way home. I then restarted it, and had no warning lights stay on. The car ran fine on the way out there. Im going to see if I can limp it up to Checkers tomorrow, and use their scanner, to see what code it stored. What do you think could be the problem?
I saw a similar thing on a 2001? Denali; low & hunting idle, and watched the mechanic clean the plate in the throttle body... problem solved.
I had a similar thing happen to an older Bonneville, and it was the battery. The voltage was low enough to create havoc on the electrical system. Check the voltage.
Good luck.
Good luck.
