Sponsored by: CARiD
Best Head Lights
Old Feb 1, 2006 | 01:36 PM
94greenFormula's Avatar
Default Best Head Lights
Hello every one Kinda new here on the bords just bought my first Forth Gen Firebird Formula. The question I have is what are some good replace ment head lights to get some more veiwing distance. The stockers are ok but I do alot of driving on 2 lane paved Farm roads at night were it gets pitch black and I cant see jack.
Thanks
Old Feb 1, 2006 | 01:53 PM
ls1charged's Avatar
your brights are not enough?
Old Feb 1, 2006 | 03:56 PM
Camaro Hamster's Avatar
Check into Hella H-4 and H1 headlamps.
Old Feb 1, 2006 | 07:20 PM
Abidar's Avatar
i switched to silver stars... HUGE improvement. They were expensive back when I bought them, I think you can get regs and brights for 40 dollars total.
Old Feb 1, 2006 | 09:09 PM
prince xizor's Avatar
Silver stars wont work in our birds. You have to look into a sealed beam conversion. Eurolites is a place that will sell them for like 160 bucks for all 4 lenses and new bulbs.
Old Feb 1, 2006 | 09:57 PM
99PontTA's Avatar
i'll tell you what i did that really helped...replace the low beams with highs...you'll need to replace the sockets too...get um at rock auto.Nice to drive now
Old Feb 2, 2006 | 12:52 AM
Jditlfm's Avatar
He has an Lt1 bird their is only one housing on each sides vs the seprate housing you have for high low. I have heard that Hella makes realy good housings for us and thats the cheapest best way to go.
Old Feb 2, 2006 | 01:51 PM
SprayedLT1's Avatar
Sylvania makes a sealed beam Silverstar that is a direct replacement for stock. It is part number H4666ST, and is the same light my winter beater Daytona Turbo uses. I have Silverstars in both my 'Tona and my Z28, and I love them.
Old Feb 2, 2006 | 07:24 PM
Sebring 00's Avatar
Are HIDs (high intensity discharge) available for the car?
Old Feb 3, 2006 | 10:24 PM
That might work in your Z28 but this is what is listed for the 98+ Trans Ams
Lamp Replacement Guide
Auto Lamp Replacement Guide - Results
Head straight to the Performance Shop and purchase the SilverStar or Xenarc products that fit your vehicle. Or print out the list and find them at your nearest retailer.
1999 PONTIAC Firebird Trans AM
Low beam headlamp
H4703
High beam headlamp
H4701
Parking light
3457ALL
3457AST Silverstar Signal Lighting: Complete the Look: Crisp, Clean, Style
Front turn signal
3457ALL
Rear turn signal
2057
2057LL Long Life Upgrade: Up to twice the life of the standard lamp
Tail light
194
194LL Long Life Upgrade: Up to twice the life of the standard lamp
2057
Stop light
2057
High mount stop light
921
921LL Long Life Upgrade: Up to twice the life of the standard lamp
Fog/Driving light
880
880ST Silverstar High Performance Lighting: the whitest and brightest Halogen
License plate
194
Back up light
1156
1156LL Long Life Upgrade: Up to twice the life of the standard lamp
Front sidemarker
194
Rear sidemarker
194
Glove box
194
Map light
212-2
Dome light
906
Step/Courtesy light
194
562
74
Trunk/Cargo area
562
Instrument-general
161
37
Directional signal indicator
161
Old Feb 4, 2006 | 11:00 AM
SprayedLT1's Avatar
Low beam headlamp
H4703
High beam headlamp
H4701
Parking light
3457ALL
Front turn signal
3457ALL
Rear turn signal
2057
Tail light
194
2057
Stop light
2057
921
Fog/Driving light
880
License plate
194
Back up light
1156
Front sidemarker
194
Rear sidemarker
194
Glove box
194
Map light
212-2
Dome light
906
Step/Courtesy light
194
562
74
Trunk/Cargo area
562
Instrument-general
161
37
161
The thread starter apparently has a 94, which would be the LT1 body style, which uses an H4666ST sealed beam headlight. Sylvania makes a Silverstar direct replacement for that car.
My Z28 uses completely different headlights, as it has a quad light set up. It uses a 4351 low beam and 4361 high beam, but there is no Silverstar for those. So, I converted my headlights to accept a 9006 low beam, and a 9005 high beam, both Silverstars. For the LS1 body style Camaros, the 9006/9005 combination are direct replacements for stock.
The LS1 'Birds, however, are out of luck as far as I know. You say Eurolites makes a kit for the LS1 birds; that's the first I have heard of that kit. Other than that, there is no other alternatives for aftermarket headlights other than the "fixed" headlight kit that eliminates the flip up headlights that I know of.
