will bad cats cause transmission lag?
![Werd](https://ls1tech.com/forums/images/smilies2/werd.gif)
Location: Live Oak, FL - in the woods where the creatures lurk.
Edit: OK, I went to the link. -whew!-
Next thing you know everyone wants a 10 sec truck
'round here!
LS1Tech Administrator
Received 1,782 Likes
![](https://ls1tech.com/forums/images/ranks/ls1tech20year.png)
Originally Posted by phantomzer0
but it only lags when its cold.... when it warms up its great
Clogged cats can cause a extremely rough idle and cause 'no power' when accelerating. (ie. accelerates like a ride-on lawnmower.)
I've never seen one cause a transmission problem.
Originally Posted by gwj
Are you running 10's in the Silverado???
'round here!
'round here!
![EEK !!](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_eek2.gif)
I had a 4l60E go out and then shortly there after the cat had to be replaced.
The car would not accelerate at all and would not go over 3000 RPM's. Plus when you looked under you could see the exaust shaking before the cat and smoke coming out around it.
Yeah mine was trashed. When the guy took it out and it crashed to the floor, about 10000 pieces went everywhere. It took the guy's 7 year old apprentice 10 minutes to clean it all up. LoL.
I agree with the overall census. If your cats we're bad you would have major problems, the manifolds would also be glowing red. If you just had the tranny re-built you wouldn't think there would be problems, I would check out your 02 Sensors, I've heard they can act up when it's cold, but once they get warmed up there is no problem. Usually they throw a code though, otherwise go back to the transmission shop. I'm sure you got a warranty, unless you did the re-build yourself.
