Can someone tell me how to Refill an A4 tranny?
When I did mine on my previous car I had installed a converter and a tranny cooler. So it was more than 5 qts. Look in the owners manual under capacities and see what it says with a filter change. That should get you close, then you can add more if needed. Good luck man.
LS1Tech Administrator
Received 1,493 Likes
Yep, 4-5 quarts for a pan drop and filter change is normal.
1 Post
When I did mine for the first time last year it was 4 qts with a pan-drop and new filter.
Put in 3.5 or so and check. Put in another .25 or so and check. Repeat until you get where you want to be. Don't forget the hot/cold difference.
