Help losing power and gas mileage
Old 02-09-2006, 11:45 PM
Cchris1109's Avatar
Default Help losing power and gas mileage
ok so before i start replacing everything.
I recently installed headers, mid length edelbrock, i checked to make sure any exhaust leaks, i found one header bolt way loose and tightened it so its now sealed to my knowledge *at least i think so*, about 2 days after installing the headers, ive had significant power loss and decreased MPG, not sure what it is here is the current condition of my car:
the AIR and EGR is disconnected
i dropped the o2 and the red part hit the g round when it dropped *not sure if thats a possibility*
car has been sitting for a year or so 1 1/2 months ago *i just got the car*
new spark plugs *not wires*
curious on what it may be...im thinking o2s
the headers are making it so hot its hitting the wires so i may need new thicker, better wires and a relocation kit
header gaskets *appeared good* but could be burnt now?
need feed back!
Old 02-10-2006, 11:06 PM
rich Z's Avatar
Your probable running rich. I've read that headers will do this. Get the car dyno tuned.
Old 02-11-2006, 09:00 AM
SprayedLT1's Avatar
Check all the plug wires to be sure that they are not burned. If the headers are coated inside, there's a possibility that the caoting is burning off and coating your O2 sensors.
Old 02-11-2006, 01:55 PM
ArcticZ28's Avatar
Once you check and make sure it's not loose/burned plug wires or crapped up plugs, get a tune, that's where your lost power is going to be.
Old 02-13-2006, 01:55 AM
Renegade's Avatar
Yep, a tune is pretty much a MUST DO... after you do headers. I would look at a sponser such as PCM For Less or Mad Z28, unless you have the money and want a Dyno Tune.
