Sponsored by: CARiD
squeakin door hinge
Old Feb 12, 2006 | 03:49 PM
Phoenix 5.7's Avatar
Default squeakin door hinge
damn driver side door is squeakin like a **** when i open and close it. remedy?
Old Feb 12, 2006 | 05:13 PM
john shea's Avatar
Put alot of grease on it. It's not a permanent fix but it helps a lot.
Mine usually starts squeking and popping in the summer.
Old Feb 12, 2006 | 05:35 PM
screaminbird's Avatar
I just use a spray lubricant(ex. wd-40) it seems to work for about 4-5 months before u have to do it again.
Old Feb 12, 2006 | 05:51 PM
ls14pwr's Avatar
I just fixed mine. Loaded it with 3in1 oil. Kinda embarassing gettin out of a bad *** car and havin the door squeek to hell.
Old Feb 13, 2006 | 01:48 AM
Renegade's Avatar
I think we are all plagued with the squeaking doors, mine tends to sag at times as well, and needs adjusted. I just spray it down with WD-40 and it's fine for a couple of months. Kinda one of those normal problems like the squeaky hatch you fix with Electrical Tape.
Old Feb 13, 2006 | 09:22 AM
OnA Fan's Avatar
WD-40 did nothing for me. I need to grease the crap out of it.
Old Feb 21, 2006 | 03:25 PM
95WhitetopTA's Avatar
The best lubricant for door hinges is red spray grease.It goes in thin like an oil but then solidifies.The can's actually show a door on them..it's an application engineered door grease etc.(think berkebile 2+2 makes some as well as others)oil,s are to light under the weight and last minimally.Hope this helps.
Old Feb 21, 2006 | 07:37 PM
Radcat's Avatar
WD-40 only works a few days with me. I spray mine down with silicone. It seems to work awhile longer.
