is this a safe way to change the oil?
Originally Posted by 1994Z28Lt1
all you gotta do is drive one side of the car up onto a curb so both the front and rear tire are on the curb and you have enough room to shimmy under there to do your oil
Frankly, I just use the "Curb". I drive one side of the car up on the Curb so the car is @ a slight angle, then Move a Hydro Jack underneath to lift just a little bit, slide under, remove oil pan bolt, get out,lower jack...oil comes out. If you have a high enough Curb, you Prob. don't need a Hydro jack.
But to answer your Initial Question, No, Do not rely on the Spare tire Jack !!! It is not designed to lift the whole car. Even 1/4 the weight makes me wonder how something so small is able to lift such a big car. It's really only for Emergencys. Like changing your spare on the side of the Freeway. If you can Call a tow truck, and Are willing to wait 45min-2hrs, then so be it.
Moderator
I would not do it that way. Way too dangerous. Get Rhino ramps @ Wal mart for $25. or have Wal mart change the oil for you. They actually change oil with Synthetic for about the same as it costs me to do it.
ok guys...while we're on the subject and not to sound like a dope...but what's the actual oil capacity on the ls1's? this is my first ls1 as my former car was a v6...and soon enough i'll be due for an oil change...thanks guys
![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
Originally Posted by 02LS1WS6
ok guys...while we're on the subject and not to sound like a dope...but what's the actual oil capacity on the ls1's? this is my first ls1 as my former car was a v6...and soon enough i'll be due for an oil change...thanks guys ![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
5.5 quarts.
http://www.installuniversity.com/ins...oil_change.htm
fyi...there are many stores about wal-mart mixing and matching oil example 2qt mobil 1 5w-30, 2qt mobil 1 10w-30, 2qt exxon 20w-50 i know ppl that used to work in TLC and some of the stuff they say is just crazy i would never let someone else change my oil after hering that kind of stuff.
#32
Your life isn't worth changing your oil, or a limb for that matter. Jack stands are a must, or take it to a place and hover over them like a Hawk. I'm always up my mechanics' ***, they let me do my own oil changes with their lift now. =)
#34
Originally Posted by 2K2WS6TA
Go to wal mart, and get some rhino ramps (you can also get your Mobil One there too) you'll be able to drive a stock T/A up on those ramps no problem, then you won't have to worry about the jack (the ramps are ~$22)
#35
Originally Posted by Arachnotron
![Icon Confused](https://ls1tech.com/forums/images/smilies2/icon_confused.gif)
#38
i've broken two spare tire jacks. Both times the weight of the car shifted a little, and they just bent right in half. Twisted the threaded rod. I'm careful while using it to change a tire, i will avoid putting my hands under anything that will take them off if the car falls.
#39
either use rhino ramps or get some peices of 2x8 and stack them like steps and drive your car up on them. your college doesn't have a lift? alot of colleges have one. become good friends with the maininance guy who runs the shop and change your oil while standing under your car.
