Oil around filler cap of engine?
If there is oil around the filler cap of an LS1, what would you think caused it? Hitting something (like a speed bump) at a high rate of speed and oil spilling out? The cap wasn't loose either. For the record, this has never happened to me but saw a car like this a couple days ago.
Possible that someone didn't get all the oil in the engine and got some on the engine. Not likely from hitting a speed bump, and if the cap was loose the engine can shoot oil from the filler. But if it wasn't loose then someone probably didn't fill it to well.
