Sponsored by: CARiD
Stuck Lugnut
Old Feb 24, 2006 | 01:01 PM
lgobraves's Avatar
Default Stuck Lugnut
Ive got a lugnut that will rotate freely around the stud but ill not come off. Any ideas on how to get it off? It looks as if the stud will need to be replaced also. Anyone have a writeup on how to do it?
Old Feb 24, 2006 | 01:30 PM
01Z28M6's Avatar
Does the nut look like it might take a key? A strange squiggled slit on the face of the nut. It sounds like you're trying to remove a locking lugnut....
Old Feb 24, 2006 | 01:43 PM
lgobraves's Avatar
no...it spins freely like either the lugnut is stripped or the stud is stripped. It will not catch a thread so it will not tighten or loosen at all
Old Feb 24, 2006 | 05:44 PM
Syxx613's Avatar
ull prolly have to cut the lug nut off. hope u have air powered or electric powered tools. other then that i would say its time to take it to a shop.
Old Feb 24, 2006 | 09:19 PM
peterlawl84's Avatar
i had that happen to me also, i didnt have an impact gun up here so i took it to a shop and they got it out for me.
Old Feb 24, 2006 | 09:31 PM
Mr Incredible's Avatar
Are you sure the nut is spinning on the stud, or is the stud spinning freely in its hole?
If the stud is spinning freely I would think you'd have to either air chisel off the head and pull it out or somehow cut/grind off the head. Hopefully, it's only the stud ribs wore off and not the hole wallowed out.
Either way, getting the head off may be how you'll have to remove it.
Just a thought...
Old Mar 16, 2006 | 06:04 PM
98charlize's Avatar
take a socket that is a little to small and hammer it on then us an impact. pull backward while trying to take it off.
Old Mar 17, 2006 | 10:02 AM
jmm98LS1's Avatar
Just cut the stud off and replace the stud and lugnut. It'll take like 10 minutes. Good luck!
