Whats everyones choice on wires??
Havent done a tune up since i got my car back in july and it is used, so i'm looking into getting some new wires with new NGk TR55 Plugs..so what wires do you have in your car, or what would you recommend???
also what else should i do tune up wise to my car???
thanks
thanks
ЯєŧąяĐ Єl¡m¡иąŧøя ™
I have a set of Thundervolts and a set of MSD's. 6 of one half dozen another. I don't think that there is really one set of wires out there that I would not recommend that is common on the LS1's. Stockers are fine too FWIW.
Tune up wise: change your oil, plugs, and recharge your K&N.
I've got the MSD 8.5s on my LT1, most people don't seem to recommend one over the other as long as you're getting something with good insulation and low resistance. The resistance is pretty outrageous on the stock wires because (I read) they have to comply with (FCC?) regulations on interference... I heard you used to be able to tune your radio to a particular AM station and pick up the signal from your wires..
they sell the K&N recharger kit at pepboys, thats where i got mine and you get cleaner and filter oil. just make sure when you clean the filter you let it dry out after you wash it with the cleaner and water, and dont spray to much oil on the filter it wont be dark pink like it was when it was new either.
