160* Thermostat...
This is also aided by the addition of a fan control switch (to manually turn on the fans when you want to) and/or the re-programming of the PCM to turn on the fans at lower temps.
If you dont change your fan settings you wont see a difference. You car would run cooler just by changing your fan settings with the stock stat.The Best V8 Stories One Small Block at Time
Just because you dont live in a city or somewhere there is alot of stop and go traffic doesnt mean the original poster does. I should of been more clear and broke down all the geographics of the US. No matter what, running a 160* stat without the fans being reprogrammed does not help if you live somewhere where it gets hot with a lot of stop and go traffic. Its been proven you dont even need to run a 160* stat in a LS1. Just by reprogramming or using a manual fan switch to have the fan come on sooner with even a stock stat makes a huge difference in the temp of the car.
I just wanted to add that the only reason I run a 160* stat is because I live in Vegas with a lot of stop and go traffic and in the Summer it gets 120*+ alot.
I dont know if your disagreeing or agreeing with me, but either way I know what you are saying. It just doesnt apply to everyone.
