Sponsored by: CARiD
smoke from exhaust...
Old Apr 29, 2006 | 10:28 PM
z28_n_tx's Avatar
Default smoke from exhaust...
I posted in a diff. sec. but no one answered, maybe someone here will...last night i reved my car (high RPM's) and i noticed smoke coming from my exhaust...i think it was white..any idea to what the promblem maybe?? checked oil level and it looksfine. I have also notice the smoke in several different mornings when i first start it up..not huge clouds but enough to where i notice when standing behind the car. should i be worried????
Old Apr 29, 2006 | 10:29 PM
Z28LS1camaroguy's Avatar
Coolant burning, have you checked your coolant levels??
Old Apr 29, 2006 | 10:47 PM
z28_n_tx's Avatar
i checked last wk it looked fine. ill check it tomorrow though. im confused ...how would the coolantburning comeout through the exhaust??
Old Apr 29, 2006 | 10:55 PM
CRAGER's Avatar
Administrator
Head gasket.
I would not worry about it. You rev'ed up the motor, probably some oil blow-by, or sucked some oil through your PCV system.
And again when you start it up in the mornings, that is probably condensation in your exhaust. Was that smoke real "light" and not so dense?
Just keep an eye on your oil level, and make sure water is not mixed up with it, and the same for coolant.
And if your car smokes EVERYTIME when you start the car, then I'd say your valve seals.
Peace,
Craig.
Old Apr 29, 2006 | 10:56 PM
not sure but could be a bad gasket or something like that, has your car been running or acting funny at all while driving it??
Old Apr 29, 2006 | 10:57 PM
BLKWS.6's Avatar
imho its just water vapor, if it dissipates rapidly, get over it, also when you do this, hold your hand over the pipe (not revving obviously) and i bet it feels like something very large and surly has been breathing on it, lol. Should come away damp. Its just water. Your engine burns a TON of the stuff. Think about it...70% humidity is normal...you think your car somehow magically pulls the water out of the air before burning it? pffft
Old Apr 29, 2006 | 11:08 PM
z28_n_tx's Avatar
car has been acting fine..i havent really noticed any changes. My change oil light came on today while i was driving but went away in a few seconds. I forgot to reset it after my last oil change so that could be why. BUt last night it smoked pretty bad , the wind blew it past me thats how i noticed it. I plan on getting some LT's in a month or so..don know if this will make the case any worst or not.
Old Apr 29, 2006 | 11:32 PM
Ws6man2000's Avatar
From: Ft lewis,Ft sill and thats all i hope.Katy texas
my friends did that, but he had bad valve seals and burning oil badly what color is the smoke if its blueish then your seals are going out
Old Apr 30, 2006 | 12:04 AM
CRAGER's Avatar
Administrator
...My change oil light came on today while i was driving but went away in a few seconds. I forgot to reset it after my last oil change so that could be why. BUt last night it smoked pretty bad , the wind blew it past me thats how i noticed it. I plan on getting some LT's in a month or so..don know if this will make the case any worst or not.
No the oil change light does not make any difference. Just a reminder to change it, you already have but not reset it. So don't worry about that, and go reset it, takes 5 seconds.
Don't worry about the smoke. If your car smokes ALL the time then worry.
Peace,
Craig.
Old Apr 30, 2006 | 05:39 PM
z28_n_tx's Avatar
Peace,
Craig.
it doesnt smoke all the time... and the smokewas white..i think. It was at night so i couldnt really tell.
Old Apr 30, 2006 | 06:31 PM
2K2WS6TA's Avatar
If the smoke is white, and it usually smokes on a cool damp morning, then it's likely water vapor, and that's perfectly normal (just like an airplane leaves "smoke" trails in the sky, same thing)
If the smoke is blue, then it's oil, usually if it does it at start up it's the valve seals, not a major problem, but should be taken care of, if it's black, then that's fuel, mixture is too rich, this can happen if you put on headers, but not always.
Sounds like it's just blowing the water vapor that you get in the exhaust out
Old Jul 23, 2006 | 11:49 PM
z28_n_tx's Avatar
Well i started my car earlier today and the smoke came back again...it looked white to me i couldnt really tell. i left the car running for a good 3 minutes, and the smoke kept coming out. i took it out for a drive and didnt notice it while i was driving it. It did rain for a good 2 hrs prior to this, dont know if it has anything to do with it. I have also installed the headers and ory, almost 2 months ago. i had noticed some smoke prior to this but it wasnt as much as today. checked the oil, looked fine, coolant was abit low though. im affraid it might be something serious....should i not drive the car ??? aso the car has 54,7XX miles on it, 01. where could i get a comp. test done ??a dn hw much will it run???
Old Jul 24, 2006 | 11:24 AM
b's90cam's Avatar
I'm havign the same problem, drove my car the last 2 days and a little bit of white smoke was coming out of the hood.
