Sponsored by: CARiD
View Poll Results: Top Engine Cleaner
STP
2
2.17%
Seafoam
67
72.83%
Auto-RX
2
2.17%
Lucas
6
6.52%
Other
15
16.30%
Voters: 92. You may not vote on this poll
Top Engine Cleaner
Old Jun 9, 2006 | 10:16 AM
rgaynor85's Avatar
"seafoam"it cleans and lets the motor burn the carbon out of the cylinders and off the valves. it also clean injectors suposidly and cleans sludge from the oil system.
i see in the poll u have auto-rx i dont believe that is a top engine cleaner its a oil additive to clean sludge from the crankcase and the transmission or ps system.. it supose to work well ive seen pics from people who used it and it did work ver well. i have a bottle i just havent used it yet, i have however used seafoam and it works great for top engine cleaning and in my oil i gained about 15psi in my oldsmobile
Old Jun 10, 2006 | 12:54 PM
98jonws6's Avatar
will it get rid of a lifter tick? my motor is ticking only on cold starts for 10 to 15 minutes after it warms up its gone... im hoping this can help.
Old Jun 11, 2006 | 11:09 PM
CULATR's Avatar
how do you install the seafoam ??? Need some info might do this tomorrow when i get off work lol!!
Old Jun 11, 2006 | 11:16 PM
Domestic Demon's Avatar
Feed it through the brake booster vacuum line if you're doing an LS1. If its an LT1, you have to find another vacuum line, because the brake booster line on the LT1 doesn't feed all the cylinders.
With the car idling, just pop off the brake booster vacuum hose (it will hiss and the engine will stumble, not to worry) and feed the seafoam down the tube using a funnel or by sticking the tube directly into the can. I recommend the funnel, because its easier to modulate how much cleaner you are putting in as to avoid flooding out the engine and stalling it. You'll gwet lots of smoke, if the smoke is black or very dirty, keep using the seafoam until the smoke is white, or until you finish the can, whichever comes first. Then drive the car hard so all the loosened deposits come out
Old Jun 11, 2006 | 11:17 PM
Use seafoam, and then change to Mobil 1 Synthetic oil if you haven't done so already. It helps a lot
Old Jun 11, 2006 | 11:36 PM
98jonws6's Avatar
changed the oil to mobile one today, but noise is still there... it honestly doenst seem like its coming from the valvetrain, its close to the driver side front area, but im thinking it might be a water pump pulley or something else, ugg!!! just want this problem fixed... im bringing the car to speed inc. tom. and have them take a quick look at it. hopefully they can diagnose this issue...
Old Jun 12, 2006 | 02:43 AM
1sick'98WS6's Avatar
I know the checker down the street doesnt carry their products.. who does for sure
Old Jul 18, 2006 | 08:16 PM
bad6as's Avatar
did it for the 1st time on my dads 99 4.0 L ranger with 98k on it
did 2/3rds threw the brake booster with it runing the teh last 1/3rd i killed it. waited about 5min and ran it.
huge differance, runs smoother, more power, thinking about puting 1 more can threw it just for the hell of it.
Old Jul 20, 2006 | 03:13 PM
BigDaddyBry's Avatar
Too much of a good thing.
Wait a few (5) thousand miles.
Old Aug 5, 2006 | 04:59 PM
Berry's 98SS's Avatar
Originally Posted by GXPPOWER
what exactly does this do. remove old sludge and what not? and from what ive read its hard as hell to change spark plugs in these engines becausr the #8 is so far back? or was i reading something else.
yup the back 2 spark plugs on the passenger side are a BITCH but it can be done I had to get my little brother who has little arms to get those. But i ve heard other people say they had to take the coils off the back to get to them.Anyway good luck..........Oh and sea foam is what ive always used.
Old Aug 9, 2006 | 12:22 PM
ZFan88's Avatar
Probably not the smartest question, but does anyone have a pic of what vacuum line to use on a LT1? I'm not too familiar with it but pick stuff up quick if I see it..
I'm going to do it this weekend
Old Aug 9, 2006 | 05:28 PM
  #32
blk97z28's Avatar
dam can this only be used on ls1's i wanna clean my 97 lt1! by i don't want to go throug plugs wires and opti! that opti is 400!
Old Aug 9, 2006 | 06:06 PM
  #33
bad6as's Avatar
no u can do it on lt1's also
the ony thing that it might make go bad would be the plugs
Old Aug 19, 2006 | 12:00 AM
  #34
irnbru83's Avatar
i just ran seafoam thru my oil and in 110 miles my oil went from a nice golden colour to a crazy black colour. Must've been a ton of build-up over 65k miles.
Stilll in the process of running it through my fuel and I haven't had the ***** to unhook a vaccuum hose yet.
Old Sep 1, 2006 | 12:23 PM
  #35
slimcracka's Avatar
i just did mine and when i shut it off after running it in the vaccum line it clunked and ran for a sec with the car off..lol i thought i broke it.. i waited a while and crunk it up and smoked the neiborhood OUT lol..and it runs better and has a nice smooth idle..love it..already did the GF`s 4.3 s10 and it even smoothed out the idle..great stuff..
