Sponsored by: CARiD
View Poll Results: Top Engine Cleaner
STP
2
2.17%
Seafoam
67
72.83%
Auto-RX
2
2.17%
Lucas
6
6.52%
Other
15
16.30%
Voters: 92. You may not vote on this poll
Top Engine Cleaner
Old May 2, 2006 | 04:44 PM
slow78z28's Avatar
Default Top Engine Cleaner
I was just curious to know what everyone thinks is the best with the least cons.
Old May 2, 2006 | 05:22 PM
brad8266's Avatar
Most use seafoam or GM top end cleaner. They are about the same.
Old May 3, 2006 | 07:56 AM
JSmee99T/A's Avatar
is it really that great to do?
Old May 3, 2006 | 09:27 AM
GregWS6&z28's Avatar
Seafoam. It's cheap and easy to find.
Old May 3, 2006 | 10:06 AM
Domestic Demon's Avatar
Seafoam is great stuff, I've used it on a bunch of cars and it really cleans the engine out well
Old May 4, 2006 | 09:23 AM
slow78z28's Avatar
Im always worring about clogging sensors or something...
Old May 5, 2006 | 02:50 PM
tbick's Avatar
do you usually change spark plugs after using seafoam?
Old May 5, 2006 | 11:19 PM
slow78z28's Avatar
its a good idea to do
Old May 6, 2006 | 01:21 PM
1999Z28's Avatar
what kind of sensors could you clog>??...exactly, none, lol.
Old May 6, 2006 | 02:13 PM
Sgt. Spuds's Avatar
Shirley Temple Drinker
O2's, its known that seafoam can clog o2 sensors.
I used LUCAS b/c I didn't wanna go threw the trouble of sea foam, but I will sea foam before my next oil change.
Old May 6, 2006 | 11:12 PM
It says right on the can O2 Sensor and Catalytic Converter safe.
Lets not spread rumors...
Old May 6, 2006 | 11:32 PM
blackbirdls1's Avatar
I'm hesitant to use this sea foam stuff, my car has less than 50k miles, and I also have a set of plugs and wires here sitting here waiting to be installed.
Old May 7, 2006 | 03:06 PM
Black FormulaLs1's Avatar
i have always used meguires hot wheel rim cleaner for my LS1...its great for all aluminum parts so i figured why not my all aluminum LS1? and it works GREAT!!!
Old May 7, 2006 | 04:30 PM
Do the Seafoam first, and after the engine is all cleaned out, install the new plugs and wires. It should be just like new
Old May 8, 2006 | 12:44 AM
slow78z28's Avatar
vroom vroom!
Old Jun 4, 2006 | 02:41 PM
ApacheDrill's Avatar
GM makes a decent top end cleaner.. works great
Old Jun 5, 2006 | 11:03 PM
ChocoTaco369's Avatar
Tech Resident
seafoam's great because it's so versatile. you can use it to clean your top end, use it to cleam your oil system, use it directly in your gas tank...and it's only 5 bucks at advance auto. c'mon, the choice is obvious!
plus it's O2 and catalytic converter safe, and it's fun as hell to blue-smoke a busy highway
Old Jun 7, 2006 | 09:04 PM
jic's Avatar
jic
seafoam for the win
Old Jun 7, 2006 | 10:53 PM
99Custom's Avatar
LOL...Read the thread again..and you'll see why your post is making me
Old Jun 8, 2006 | 07:11 PM
GXPPOWER's Avatar
what exactly does this do. remove old sludge and what not? and from what ive read its hard as hell to change spark plugs in these engines becausr the #8 is so far back? or was i reading something else.
