Sponsored by: CARiD
rear seat delete
Old May 6, 2006 | 04:39 PM
blk97z28's Avatar
Default rear seat delete
Hey i have a 97 black camaro z28 and i wanted to do a rear seat delete but i go the two back seats out and i can't figure out how to take off the back rest for the back seats plz help!!
Old May 6, 2006 | 04:44 PM
ss1129's Avatar
Theres on only 2 nuts that holds it in. They are right on the bottom corners.
Old May 6, 2006 | 07:23 PM
blk97z28's Avatar
Default hey thanks
do most ppl do rear seat deletes?
Old May 6, 2006 | 10:01 PM
ss1129's Avatar
Most people...I would say no. If your going to the track then it may be worth doing if you want the best times possible.
Old May 7, 2006 | 01:06 AM
staringback05's Avatar
seen someone with a sweet system in his without the rear seats
Old May 7, 2006 | 01:47 AM
2002_Z28_Six_Speed's Avatar
The rear seat doesn't weight anything at all.
Old May 7, 2006 | 01:52 AM
ss1129's Avatar
**** adds up.
Old May 7, 2006 | 04:51 PM
blk97z28's Avatar
hey thanks but also how do u the seat belts out of the little black shaped thing they run through
Old May 12, 2006 | 02:50 PM
Dserby1's Avatar
Anyone have any idea on this? I'm trying to delete my rear seats but I would like to leave the belts just in case I HAVE to have someone back there. Any way to do this without cutting these plastic brackets?
Old May 13, 2006 | 01:24 AM
The front belts? You have to remove the bolt that holds it into the body.
Old May 15, 2006 | 11:08 PM
eli_pem01's Avatar
The belts are held on with a T47 torx bit.
Old May 16, 2006 | 09:16 AM
LS69TA's Avatar
If you want a pair of black ones, I've got mine that I barely used. Shoot me a PM if interested.
Old Aug 2, 2006 | 05:32 PM
blk97z28's Avatar
how do u get the belt cover on the belt itself out the little silver thing that is held into the body it is too wide to fit through the seat belt cover?
blk97z28's Avatar
nedd help asap! i want to leave the belts too!
Old Aug 2, 2006 | 06:50 PM
LS69TA's Avatar
I took a hacksaw to the guide on the back seat. Cut a slit in it, then I could slide the belt through and remove the back seat. You can't notice it, and the belts can stay in place. I ended up removing mine all together later on, but that's one way to do it. Maybe that answers your question.
Old Aug 6, 2006 | 12:34 PM
blk97z28's Avatar
hey thanks for now i just took out the whole seat and the belt guides!
