Sponsored by: CARiD
Flushing Cooling System
Old Jun 28, 2006 | 11:54 AM
senicalj4579's Avatar
Default Flushing Cooling System
does anyone know if its nessesary to open the block plugs to drain flush the cooling system? i'm actually thinking of taking the car to jiffy lube or somewhere to avoid the hastle with fluid but something tells me jiffy lube dosent take the plugs out of the block. any advice? thanks
Old Jun 28, 2006 | 12:23 PM
WS-Six02's Avatar
no they just have a vaccum machine that sucks the old coolant out and puts new in, they should do that twice for a flush. i would probably just do it myself if i were you.
Old Jun 28, 2006 | 06:01 PM
Flawless02SS's Avatar
Yeah DIY !! Its not hard. And no removing the block plugs is not needed, since your car is a 98 the coolant shouldnt be in too bad of shape.
Old Jun 28, 2006 | 06:15 PM
joshp14's Avatar
Actually most flush machines use the new coolant to push the old coolant out. The coolant isnt sucked out...it's pushed out in most cases. At the dealership I work at, we run the car for 10 min with the flush solution in the system, then we proceed to exchange the fluid.
Old Jun 28, 2006 | 06:21 PM
MIKE_84's Avatar
Just do it yourself. Drain system, take out thermostat, fill with water dump some cascade in it and let it get hot, then drain it run plain water in it, drain again then replace thermostat and fill with water/AF.
Old Jun 28, 2006 | 07:26 PM
joecar's Avatar
It hard to get to the block plugs, and if you can get to them, then they will drain coolant all over the alternator and the starter.
Old Jun 28, 2006 | 10:25 PM
thanks for the advice. i'm just gonna do what i was planning on doin in the first place. i'm gonna do it myself lol
Old Jun 29, 2006 | 01:28 PM
when i drain the system how do i make sure all the old coolant is out? i know i drain the radiator but i'm under the impression that not all the coolant is gonna come out this way. how do i do this?
Old Jun 29, 2006 | 02:57 PM
Marc '99T/A's Avatar
I think this is how I did it. I can't remember to be certain. I just know that I followed the directions on the container of radiator flush. Went something like this:
Drain the old fluid and fill with water. Run for about 10 minutes with heater on, then drain again. Fill with water and coolant flush...run for 10 minutes with heater on, & drain. Fill with water again and run for 10 minutes with heater on. Fill with new coolant / water mix.
As far as Jiffy Lube goes, you should really check this out.
https://ls1tech.com/forums/showthrea...ght=jiffy+lube
Old Jun 30, 2006 | 11:29 PM
wow. just yesterday i broke down and brought my car to jiffy lube for a flush. i wanted to avoid the haslte of getting rid of the fluid. i dont really have a good place to work on my car. this is the first time i ever saw that jiffy lube video. wow! but the thing is i was standing right by my car the whole time and i saw exactly what they did for a flush. i got new coolant put in but with that machine they use i can tell you its not anywhere near as good as if you drained the radiator and did it that way. next time i'm gonna make more time for myself and do it myself
Old Jul 1, 2006 | 02:56 PM
ws6chicken's Avatar
When you put the cascade with water and run the car, do you want to lower the car so that it is level, or is it all right to do it with the front up in the air.
Do you think you could use a shop vac to get absolutely all the coolant out of the car as well as when you are cleaning the engine with cascade/water.
Art
Old Jul 1, 2006 | 04:38 PM
SOM_of_a_Beach's Avatar
Does anyone know where I can find a how-to guide for flushing my radiator that has pictures???? I would feel more comfortable if it had idot proof pictures.
Thanks,
Crystal
Old Jul 2, 2006 | 05:46 PM
MIKE_84's Avatar
I never have really thought about not having the car level. I always do mine with it on the ground, but i dont see where it would really hurt with it on jackstands. I wouldnt worry about using a shop vac, you can just opent the drain plug and keep a water hose in the radiator while the cars running until clear water is coming out.
Old Jul 2, 2006 | 08:43 PM
oh well, did it, got it done and replaced head lamps, turning indicators, and chnaged a broken ***.
