Sponsored by: CARiD
silverado problems
Old Jul 5, 2006 | 05:29 PM
captaincamaro's Avatar
Default silverado problems
we have an 04 silverado 2500HD with the suspension package. it just hit 75k miles and theres now a weird noise going from reverse to drive. its like a clicking. then under high acceleration it vibrates alot. i think if were lucky its just the u-joint but before we take it in id like to see what you guys say
Old Jul 5, 2006 | 05:47 PM
joshp14's Avatar
IS the noise there while driving or just when shifting between the gears? A lot of the rear u-joints go bad on these trucks due to lack of lubrication. They have also came out with a new slip yoke new help the D-R-D shift "clunk" that some people have.
Old Jul 8, 2006 | 09:25 PM
it happens when changing gears and accelerating
it also has the clunk you talk about where can i get the new slip yoke?
thanks
Old Jul 8, 2006 | 09:38 PM
v8's Avatar
v8
17,16,15,14,13,12,11 Drvr
it could be the great emergency brake pads the chevy has, its only held in place by #6 screw, is the vibration coming from the rear or the front?
if the front its the front wheel bearing, price is about 170 bucks
if its from the rear it could be drive shaft out of balance,u-joints, yoke, breaks are warped from emergency pad holding the rear disc,
if you go to performancetrucks.net you will find alot of info there.
Old Jul 9, 2006 | 08:31 PM
97MysticZ's Avatar
What's a Sticky?
Sounds like a bad u-joint to me...
