Sponsored by: CARiD
Replacing A/C Compressor
Old Aug 19, 2006 | 01:00 AM
00silverT/AWS6's Avatar
Originally Posted by andypz28
how much did you guys pay for the AC compressor and all the supplemental parts?
and where do you buy them for cheap?
autoaironline.com was the cheapest I found after seaching for days.
Old Aug 19, 2006 | 01:04 AM
Originally Posted by SilverSierra
The compressor does not hold 9 ozs
I'm sorry but you are wrong. A fully drained compressor will hold 9 ozs of oil. I just filled one with 9 ozs a few weeks ago, and thats what the instruction sheet that came with the compressor said to fill it with. If yours only took 4 then you obviously didn't drain it completely.
Old Aug 19, 2006 | 02:22 AM
Spellbound's Avatar
My compressor is leaking....I went to a stealership and they wanted 1200 to fix!!!
I will be doing this one myself.....
As far as a pump, reman or new?
Old Aug 19, 2006 | 08:49 AM
Billy_B4C's Avatar
Well, I got this done, but I did not do it...I paid a guy that has a shop at his house a little over $600 to do it, and that was with parts included. I watched the procedure, and his lift made it a LOT easier, I imagine. He DID flush it, and I'm glad the did for all of the goop and crap that came out. The old compressor was a reman unit, but the new one is a brand-new Delphi unit. I got the dryer/accumulator replaced, along with both belts. Not too bad considering that I have to turn the A/C all the way to low now...even with this South Alabama temperature. I'm extremely pleased with the work, if anyone in the Mobile, AL area wants the mechanic's info pm me and I'll hook ya up with him. BTW, he's a former USCG aircraft mechanic, so he knows his **** and doesn't half-*** anything.
Old Sep 3, 2006 | 04:59 PM
MiaSSmaro98's Avatar
okay im doing my ac in 2 weeks so how many oz of oil will i need on a complete new system?
Old Sep 19, 2006 | 01:48 AM
hey guys quick question i know that the system charge is 1.5lbs but does that include oil or its 1.5lbs of r134 and 9oz of oil?
Old Sep 19, 2006 | 08:43 PM
iverson387's Avatar
does anyone know how to change the clutch assembly without taking the compressor off the car. do i just have to take off the belt and take it off with a puller or is it more involved.
Old Sep 27, 2006 | 11:22 AM
pSSycotic's Avatar
i had to have my whole system changed a month ago..after labor and parts it was $900...new compressors alone are $515
Old Sep 28, 2006 | 08:58 AM
ghettocruiser's Avatar
That site listed above is the best for pricing. I got my parts from ackits.com. At the time, their driers were $60... now they are up to $88. Either way...when ordering A/C parts, make sure you get the right seals.
These are listed as "GM COMPLETE SYSTEM O-RING KIT 1989-2004"
I didnt find any on my car like this...
These are the ones I needed and most likely you will need too.
"GM SEALING WASHER ASSORTMENT 2004 & PRIOR"
These worked perfectly.
Also..my compressor wouldnt take more than an once or two of oil. I distributed the rest in the drier, compressor line, and alittle in the condensor line. That was all of the 8oz can. THere was probably more than an oz left in the condensor and the evap from when I removed and capped them.
Justin
