Replacing A/C Compressor
1) I know I need to have the system flushed...when do I do that? I'm assuming when the old compressor is off and the system is open?? Do I do that with the new or old dryer/accumulator?
2) Are there any seals/gaskets/o-rings that I should know about or have to buy separately? I'd hate to miss one of those and *** up the whole job.
Any and all advice/lessons learned would be greatly appreciated!
I bought a new accumulator, it came with the necessary gaskets. I replaced the orifice tube. It sits in the liquid line (hard metal line below accumulator line) on the evaporator side. It did not come with a new gasket, so I reused the stock one. Same thing with the suction/discharge hose assy that connects to the compressor, no gaskets, so I reused. No problems.
I removed the compressor belt, unbolted the compressor (its hard to get to a couple of the bolts, but you can do it). With the compressor loose, I removed the suction/discharge hose assy.
I then took the new compressor and filled it with 4 ozs of PAG 150 oil. I poured the oil in the suction port and turned the compressor until the oil was sucked in. Then repeated until I had 4 ozs in the compressor. Bolt up the hose assy (yes you will spill some oil) and bolt the compressor back in, but leave the belt off. Replace orifice tube. Pour another 4 ozs of oil into the body of the accumulator. Bolt accumulator back in. Go back to the compressor and spin it a dozen times by hand to circulate the oil.
Have the system evacuated and recharged. Unless you have a clogged line or the compressor exploded, I don't think you need a flush.
If I can use my current accumulator should I add more oil to it?
Also good to know I can have it evacuated just before I recharge. Thanks for all your help.
-Each item replaced requires one oz. of replacement oil.
-The accumulator/dryer should be replaced if the system is left open for any period of time over a few hours.
-Be careful straining any other lines while you're replacing the compressor. I had to replace the high pressure line the following year, possibly leaking due to stress & strain.
-The compressor is a heavy bitch, but it isn't all that difficult. About a 5 on the 1-10 PITA scale.
-If you didn't have a catastrophic compressor failure that left little bits & chunks in the system you shouldn't HAVE to have a flush. A proper flush consists of doing each part of the system separately and will be expensive if done by a shop.
-I had a shop vacuum & refill the system after I did all the replacement work. $140-ish.
-If you're using a used compressor (I got a rebuilt one at a parts store) you should need to add more than an oz or so, just to be sure. Alternately, you could remove all the old oil and add what's recommended for a used compressor (but I don't know what that is.
-If you reuse your dryer you shouldn't need to add any oil to it.
-There is a LOT of information on the web and it's a good thing to seek it out.
-Much instruction came on the sheet I got with my rebuilt compressor.
What I am saying is if your car's A/C hasn't worked for months, and you replace the compressor and the accumulator you are losing almost all of your oil. You need well more than 1 oz in each of those components.
I looked at buying a compressor on the board but every genius thinks their 100K mile POS compressor is worth 100 bucks. I bought mine at a local scrap yard for under 100 and it comes with a warranty.
