Fuel Injector Cleaner
How often, if at all, do you guys put that stuff in your car? I used to do it in my old 94 T/A, with 105,000 miles, every oil change, but I haven't in this one yet, but it's only got 39,000 miles.
I use Redline SI-1.
Actually I use some with every tank of gas, rather than a whole bottle every so often. The ratio is about 0.2 oz. per gallon of gas. Stuff works great.
I dumped a can of seafoam into my gas tank a few tanks back. Seems to idle smoother and maybe pull a little harder at lower rpms, cruising in overdrive and such...but it could just be me. 120k on the odometer though, I doubt it could have done anything but help...except for maybe break some crap out of the fuel rail and clog something. But it seems to have helped.
I use the BG 44k and their fuel induction kit. I think it is the best. A little expensive but I have seen results w/ my own 2 eyes. Replacing head gskts due to age (high mileage) and seeing no carbon in the motor. I usually put a can in my car about every 1000 miles and add it when I have about 1/2 tank left, run it for about 25 miles then fill up.
Nobody uses Xylene? Its 117 octane, sensor safe, etc. Its already a component in regular gasoline. I buy a gallon and pour it in every so often. I watched my fuel trims on my T-Type move back close to zero within 30 minutes when I first got the car after using the stuff.
Originally Posted by JerseyLS1TA
I put in the Chevron stuff, but on my highway pulls there was no smoke of any kind coming out the exhaust.
