Coolant overflow problems!!!
now what has me scared is tonite i tried to refill it. I notice that i can ust pop the rad cap off and nothing sprays out at me like my other cars. the rad is low. Start up the car (its hott) and start putting coolant / water in it. It started gysering out of the rad with extreme pressure. after that i kept filling it and eventually it just pushes the coolant out of the system. I HAVE NOTICED NO LEAKS OTHER THEN THE OVERFLOW. no puddles no leaks nothing.
I am leaning towards a bad tstat. but i am really not sure. i can see the coolant flowing in the rad so i know the water pump isn't bad.
last resort is headgaskets... but i don't see any of the symptons. This is fraustrating!!! HELP ME OUT!!
Also,
An unbled system can do this.
Here's the fill/bleed procedure for an LS-1 just to be sure you're doing it right.
6. Close the radiator drain ****.
7. Fill the system through the radiator surge tank opening up to the base of the neck.
8. Start the engine.
9. Idle engine for 1 minute.
10. Install radiator surge tank cap.
11. Cycle the RPM, idle to 3000 for 30 seconds intervals until engine coolant reaches 210 F.
12. Shut off the engine.
13. Refer to step 3 above to remove the radiator surge tank cap.
14. Start the engine.
15. Idle engine for 1 minute and fill surge tank to ½ above COLD Full mark on the radiator surge tank.
16. Install the radiator surge tank cap.
17. Cycle the RMP, idle to 3000 in 30 seconds intervals until engine coolant reaches 210 F.
18. Shut off the engine.
19. Top off coolant as necessary, to ½ above COLD Full mark on the radiator surge tank.
20. Rinse away any excess coolant from the engine and the compartment.
21. Inspect the concentration of the coolant.
