Where is my oil leak!?
![Exclamation](https://ls1tech.com/forums/images/icons/icon4.gif)
Ok! I just got my transmission pulled out because I was going to change the rear main seal which everybody told me it was... But as you can see I dont know if my rear main seal is leaking or not... It only leaks when running and my undercarriage is covered in oil.. And the oil was dripping from the rear of of the oil pan that meets to the trans. What do the pics say?
And I am running mobil 1 10w/30 and no im not changing to non synthetic
Thanks guys
[IMG]
[/IMG]
[IMG]
[/IMG]
![](http://i48.photobucket.com/albums/f234/Nemesisls1/Picture011.jpg)
![](http://i48.photobucket.com/albums/f234/Nemesisls1/Picture012.jpg)
![](http://i48.photobucket.com/albums/f234/Nemesisls1/Picture013.jpg)
![](http://i48.photobucket.com/albums/f234/Nemesisls1/Picture014.jpg)
![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
Thanks guys
[IMG]
![](http://i48.photobucket.com/albums/f234/Nemesisls1/Picture018.jpg)
[IMG]
![](http://i48.photobucket.com/albums/f234/Nemesisls1/Picture010.jpg)
![](http://i48.photobucket.com/albums/f234/Nemesisls1/Picture019.jpg)
same problem,, looked teh same i changed the rear main seal anyway,, you should to since your there.....also klean everything yup have the kar pointed noise up so the oil will flow down,,,um then next day look for wetness anywear for oil... hope this helps
I had the same problem a while back. Got a replacement cluth since I was gonna be in there and when it got down to it the rear main wasn't the culprit. Turns out the slave was leaking and dripping down making it look like the rear main. itmaybe worth a look.
check the rear main...check your oil pan bolts and see if they were tight or torqued correctly..and check the dang seal that your oil filter is housed in..i had to replace mine once before..on my car the oil pan gasket was good..the rear main leaked a TINy bit but the housing in which the oil fitler screws into was leaking ..theres an oring in there ..it may be crapped out..worth a look
Heres some more pics! I think I found the culprit. When I started removing the bolts for the rear cover oil started coming out of every bolt and when I removed the cover I found that at the top of the seal for the camshaft the seal was torn. Probably the reason why the oil is seaping all the way down the rear cover. I took a few more pics. Do you guys think that this is my leak?
Thanks
[IMG]
[/IMG]
![](http://i48.photobucket.com/albums/f234/Nemesisls1/Picture024_640x480.jpg)
![](http://i48.photobucket.com/albums/f234/Nemesisls1/Picture031_640x480.jpg)
![](http://i48.photobucket.com/albums/f234/Nemesisls1/Picture030_640x480.jpg)
Thanks
[IMG]
![](http://i48.photobucket.com/albums/f234/Nemesisls1/Picture023_640x480.jpg)
![](http://i48.photobucket.com/albums/f234/Nemesisls1/Picture032_640x480.jpg)
