Sponsored by: CARiD
Specs of metal in oil?
Old Sep 17, 2006 | 07:06 PM
ninety9ta's Avatar
Default Specs of metal in oil?
I changed my oil the other day and as I was draining the used oil into a waste container, I noticed tiny specs of metal at the bottom of the drain pan. They were about the size of a grain of salt, and probably a total of 15. The car is running fine, no over heating or weird noises coming from it. Also, the last time I changed my oil I found two shards of metal probably a little shorter then the length of a dime, and about a centimeter or two wide. Any help would be greatly appreciated. I really hope I don't have some major damage here or some possible breakage in the future.
thanks
-Alex
Old Sep 17, 2006 | 08:01 PM
HeapaShifter's Avatar
Bearings?
Old Sep 17, 2006 | 09:15 PM
staringback05's Avatar
bearings is a good bet, those usually have the tendacy to chafe or get rubbed....ive spun bearings before and had to get a new motor....u can either 1 drop your pan and your main caps and see whats going on....ALOT OF WORK...or just monitor the situation and see if it keeps doing it, i dont like the sound of the dime sized stuff
Old Sep 18, 2006 | 12:05 AM
Blk97WS6's Avatar
that doesnt sound good
Old Sep 18, 2006 | 12:08 AM
Gun5's Avatar
not good i had some little salt pieces but i just did my first 300 mile change for break in of the 355 .. id drop ur pan and look before u go snapping ****
Old Sep 18, 2006 | 12:17 AM
02 BLK WS6's Avatar
Ouch!!! Doesn't sound good....
Old Sep 18, 2006 | 03:42 AM
CASHss99's Avatar
Pictures?
Old Sep 18, 2006 | 09:43 AM
ninety9ta's Avatar
I'll try to take pics tomorrow, I didn't clean out the drain pan so it should still be there. The shards from the previous oil change were a little shorter then the length of a dime, not the size of a dime. Either way it can't be good. Now Im pretty nervous, should I go ahead and start saving up for a new motor? lol. Thanks guys.
Old Sep 18, 2006 | 10:47 AM
Ima get mines's Avatar
Probably just the bearings rubing on the crank, could this be signs of crank walk or just alot of high rpm use?
Old Sep 18, 2006 | 11:49 AM
Bill's 02 Z-28 SS's Avatar
Hi Folks
what is your oil pressure - good or bad? Has it changed over the last oil change? That is what I would look at.
Thanks
Bill
Old Sep 18, 2006 | 12:48 PM
Not meaning to hijack your thread but I also found something scary while changing my oil yesterday. These little rods (magneticly stuck to my drain bolt) were in my oil pan
Theres about 5 or 6 of them in there and thats it. I dont know where in the motor they could've come from Unless its an axle for a roller lifter or roller rocker I have no idea. It cant be an axle because there to small imo. The car runs fine except for the bad lifter I think it has. What is it?!
Old Sep 18, 2006 | 12:54 PM
ninety9ta's Avatar
My oil pressure is fine, everything seems to be running normal. Although I hear a minor tick coming from the engine that Im not sure if it was always there before.
Old Sep 18, 2006 | 01:47 PM
A-Dub's Avatar
Time to change your rockers, those are the needle bearings for the rocker shafts.
Old Sep 18, 2006 | 02:01 PM
Are you sure? And where exactly on the rocker arm, or rocker shaft are these located? Can somebody give me a visual? Will it dammage my engine to drive around with messed up rockers? The car seems to run fine right now.
Old Sep 18, 2006 | 02:08 PM
I think I figured out where they are,
here right?
Hopefully your right, has anyone experienced rocker arm failure like me?
Old Sep 18, 2006 | 02:58 PM
z28_n_tx's Avatar
here ya go
http://ls1howto.com/index.php?article=21
A-Dub's Avatar
You got it, go do a search in the internal engine forum, tons of discussion on stock rocker failure
Old Sep 18, 2006 | 03:09 PM
Thanks for the info guys! I'm still running stockers on a T-Rex cam so i'll be bolting some roller rockers on this weekend.
Old Sep 18, 2006 | 03:25 PM
if you break down the engine and no bearings have spun, you can just go back and polish the crank and get new bearings, if you find that a bearing has spun..........new motor my son....but look on the bright side, this is the perfect time to get that 402 youve been waiting for lol
Old Sep 18, 2006 | 04:00 PM
Old Geezer's Avatar
Cut the filter open. Use a tin snips, or a filter cutter, to make sure the "junk" you may see, is not due to the cutting process.
