Window Strips on Doors?
help please this is ruining my windows
As you know they pad eventually wears down and starts to eat your window.
my drivers door is different like i said ill probably get it from gmpartsdirect it shows $31 http://www.gmpartsdirect.com/results.cfm it should fit right? also anything to polish/buff my glass with hide the scratches
Go ahead and order the replacement part, and take a look at the fasteners when you get it. It'll make sense then.
The problem is in order to get in there and pry the clips loose, you'll probably need to take the inner door panel and supports out, and press the window inwards to get enough space to work with.
I had one of these replaced during an accident repair and the new one never hooked back in quite right. It would always lift slightly out of place rolling the windows up, and I'd have to push the fugger down every now and then. I suspect the body shop just pulled the old one up brute force method and tore up the areas where the barbs were supposed to seat. So don't do that.
