How to change fuel filter?
i geuss i need to disable the fuel pump. can anyone tell me which fuse disable the fuel pump?? and maybe if there is anything else i should know before doing something stupid again. thanks alot guys. install U. has the whole process, and according to them you need to disconect the bat. remove the fuse.
2 wrenches to unscrew the foward side line from the filter and the quick disconnect is easy, just pinch it or needle nose it.
ps.
how was the bath?
if you disconnect the battery, pull the fuse for the pump and chok the wheels and secure your neck tie and wear your goggles and remove your jewellry and not run or smoke in the shop or whatever else... how can you sart the car to run the fuel out of the lines?
You can still start the car with the fuse pulled. There's a seperate fuse for the injectors, whatever fuel is left in the lines will get used up. It won't run very long. That's why you don't disconnect the battery.
You can forget all that, and just change it. Some fuel will splash out, but it'll stop.
pull fuse, open gas cap, used pliers to unclip the one end... let it drip into a catch pan until i got bored, then just unscrewed the nuts and replaced the filter with the rubber hose still dripping.
didn't spill one drop on the concrete! do i get a prize?
LMAO
