HELP!!! Car Dying :(
Could I damaged something while limping it to work? approx 1 mile of driving. also could the misfire cause the spark plug to go bad? I'm trying to see if the obvious will solve the problem. Any help is greatly appricated.
also what are your spark readings, fuel trims, etc....how was the car tuned for the H/C swap? is the car heating up? what is the oil psi?....check back
Thanks for your reply!
did you know them?....thats just crappy people do halfassed jobs...Another thing. How common is minor misfire on this engine? is 2 to 6 misfire max acceptable? i'm getting it all across the board with the 8 cylinder now.
Thanks!
