Sponsored by: CARiD
Check Engine Light Codes
Old Jun 4, 2007 | 07:38 PM
staringback05's Avatar
o2 sensor is broke....
Old Jun 6, 2007 | 11:38 AM
SStealth00's Avatar
thanks!
just gotta find out which one now
Old Jun 6, 2007 | 04:23 PM
just buy the front 2....thats all you need, if you still throw the code tune the rears out
Old Jun 7, 2007 | 04:24 PM
NINO_SS's Avatar
i just got a P0327 code what do i do? what does it mean? help plz
Old Jun 11, 2007 | 12:34 AM
check the load on the power wire to your knock sensor
Old Jun 14, 2007 | 04:05 PM
hugger1975's Avatar
Is O2 sensor 1 the driver side or passanger?
I have code 155.
They told me its the opposite side of Cyl 1
thanx!!
Old Jun 14, 2007 | 04:06 PM
believe its the drivers side o2....however its a good policy when switching o2s to go ahead and do both
Old Jul 1, 2007 | 02:21 PM
LS1NUT26's Avatar
2000 Z-28 A-4
P0507 says it has a higher idle than expected. So what should I look for?
Old Jul 1, 2007 | 03:09 PM
intake leak, unmetered air.....
Old Jul 2, 2007 | 09:08 AM
SStealth00's Avatar
P0137 02 Sensor Circuit Low Voltage (Bank I Sensor 2)
is this on the driver side manifold or behind the cat on the passenger side?
Old Jul 2, 2007 | 04:50 PM
pretty sure its the passanger side, but like i said its good to change both at the same time
Old Jul 2, 2007 | 05:18 PM
  #32
2001NBMZ28's Avatar
Bank 1 is drivers side, Bank 2 is passenger side. Sensor 1 is precat, Sensor 2 is post cat.
Old Jul 3, 2007 | 01:53 AM
  #33
my fault had them backwards...good correction
Old Jul 6, 2007 | 11:52 AM
  #34
5 litre eater's Avatar
P0112 Intake Air Temperature Circuit Low Input
Running a diablo tune
Keep getting ses light coming on.
Old Jul 8, 2007 | 05:03 AM
  #35
check the sensor on your lid....
Old Jul 23, 2007 | 12:22 PM
  #36
Zero4488's Avatar
Restricted User
Can a lean code be from a bad O2 sensor?
Old Jul 24, 2007 | 10:36 AM
  #37
gtarist's Avatar
That gearchatter website is the bomb! I keep getting P0442, Evap Emissions Control Leak, Small on my 98 Silverado. Gonna start with a new gas cap and cross my fingers. After that, it's on the lift and dropping the tank, it looks like. PITA!!
Old Jul 24, 2007 | 12:48 PM
  #38
a bad o2 can make the car run in several different ways, but lean usually isnt one of them....you'd also be having some driveability issues...like lurching...and bad idle...for a front o2
usually on a lean code your looking at an unmetered air issue....
Old Jul 31, 2007 | 03:23 PM
  #39
SheaMus's Avatar
need help...i had my transmission rebuilt and threw in my TC...its a Vig 3600...the cars running rough...i keep gettin code P1860...its saying Manufacturer Controlled Transmission...what can i do to get this fixed? Tune? Thanks
Old Jul 31, 2007 | 03:56 PM
  #40
2001NBMZ28's Avatar
First thing to check is the ENG CTRL fuse. Here's a link that might help, if not, post in the trans section (lots more exposure than asking in a sticky). www.ls2.com/boggs/a4/DTC%20P1860%205.7.htm
