Sponsored by: CARiD
Check Engine Light Codes
Old May 27, 2008 | 08:13 PM
  #61
chemicalstylez's Avatar
My car is throwing P0200.... is this a common code? I have no idea where to start
It happend today, my car felt like it was missing and falling on its face, than my SES light actually flashed. Never saw it flash before.
Old Jun 13, 2008 | 06:18 AM
  #62
staringback05's Avatar
fix it yet?...problem?
Old Sep 28, 2008 | 12:42 AM
  #63
OffspringZ28's Avatar
Threw a P1133 (Insufficient switching bank 1 sensor 1 02)
Should I just go ahead and replace em both? wiring looks fine and a fresh set could never hurt. What do you think? ACDelco still the best?
Old Apr 23, 2009 | 11:46 AM
  #64
War Theory's Avatar
Default Please help
I have a 2001 WS6 I keep on getting a po410 code what does this mean and how do I fix it
Old Apr 6, 2010 | 11:03 PM
  #65
trockstunts1's Avatar
i got a code it ill post the actual code number in the morning but it came back to a shift selinoid im not familar with what that is any help would be appreciated?
Old Jun 6, 2010 | 10:53 AM
  #66
THE BIG KAHOONA's Avatar
My 2002 Z/28 just threw the very same codes . Did you ever get an answer from THE MAN on what exactly we need to replace or do to fix ?
Auto Zone said it was the 02 sensors . Which is it pray tell ?
CODES P0171 & P0174
Old Jun 6, 2010 | 11:07 AM
  #67
Could someone explain how to fix or what to replace with CODES P0171 & P0174 .
THANKS
Old Jun 8, 2011 | 12:17 AM
  #68
My BAD TA's Avatar
my car just threw these
P0131 p0137 p0151 p0157
and i cant figure out for the life of me what i need to do to fix them..
Old Jul 1, 2012 | 04:32 PM
  #69
temiller's Avatar
Question check engine light codes
Hello, I just recently had my engine rebuilt. I have a 1995 Camaro Z28 LT1, I got eberything put back together and my check engine light is now on.
I am getting two codes. The first one is 043 Elec Spark Control (ESC) Module or Sensor Problem. The other one is 084 Output Driver Module (ODM) Fault Skip Shift Circut.
I put a new MSD distributor on when I was putting the car back together and the car seems to run fine. So I am having some trouble figuring out what the codes are there for... anyone have any ideas or suggestions? Thanks.
Old Jul 13, 2012 | 08:46 PM
  #70
T-Bones Goat's Avatar
I am getting a P0787 code which is shift/timing solenoid low. Has anyone had this issue?
Old Jul 21, 2012 | 07:21 AM
  #71
Darthscooby1001's Avatar
I have a P0785 shifter solenoid fault. I have changed the solenoid also changing the fluid and filter at the same but the error remains. After 10 minutes of driving I can clear the code and it stays off for the rest of the day. When the engine is cold again or the next morning the error is back and is very infurriating!
Can anyone offer any advice please? My ride is a 99 Trans Am Conv.
Old Oct 4, 2019 | 10:35 AM
  #72
Christina Lynn's Avatar
So i need help understanding the Skip shift. I have a 2012 ss, completely rebuilt nothing stock. I got it running about 3 months ago, and about two weeks ago it starting acting like it wanted to throw me out of third and my check engine light came on. So i was going to head straight to a scanner. On the way it got worse, It started doing it in 2nd, 3rd, and 5th. Then when i pulled up to Advanced and scanned it, there where like 13 codes. Skip shift was the biggest one that popped up. Then i lost my reverse so i had to roll it back and it let me get it home but now when i try to start it it turns over and just dies, We unplugged the battery to try and reset it and the skip shift still shows on the scanner. My tuner says he tuned it off but didn't delete it. Any opinions or advise ?
Codes:
P0801
P080C
P0056
P0036
P069E
P2534
