Sponsored by: CARiD
Check Engine Light Codes
Old Jul 31, 2007 | 09:49 PM
  #41
SheaMus's Avatar
thanks
Old Aug 6, 2007 | 05:14 PM
  #42
Spitz's Avatar
what if the code scanner doesn't even turn on when connected to the vehicle? i hooked it to my truck and it fired right up, tried the 'bird and nothing. still works on the truck. brand new from autozone today, please help?!!!! the car won't stay running
Old Aug 10, 2007 | 09:39 AM
  #43
staringback05's Avatar
turn the key into the on position.....
Old Oct 8, 2007 | 05:59 PM
  #44
2000Z28ls1's Avatar
I threw code P0151 02 sensor circuit low volts (bank 2 sensor 1) I went through a puddle today couldnt avoid it slowly, I checked the sensors just a min ago and they were fine I have long tube headers and ORY and the wires arnt burnt or anything what else could It be I just put these new ones in with the Bosch ones so there new IDk what to do, also another pending code was code p1153 manfacurer contrl fuel air metering but on gearchatter is says its a diffrent one so what could that be? any help would be great!
Old Oct 8, 2007 | 06:58 PM
  #45
Ron T's Avatar
I need some ones expertise-My car is shooting off code PO 300..Random/multiple cylinder misfire detected.I replaced the plugs and it got worse.It feels and sounds like Im hitting the rev limiter the whole time Im driving....All I know is to check the Optispark.Any thing else??? Please help; Thanks Ron,T
Old Oct 19, 2007 | 07:59 PM
  #46
GOT LS1's Avatar
my buddys car through a code, I dont remember what it was, but He ended up having a broken push rod on the number 8 cylider. It was making a horrible noise. was you engine light flashing?
Old Dec 5, 2007 | 02:59 PM
  #47
streetsurfinseth's Avatar
how much are those code readers cause i need to get one to read my 00 t/a
Old Dec 13, 2007 | 04:13 PM
  #48
BLULS1Z28's Avatar
P0354 Ignition Coil D Primary/Secondary Circuit Malfunction
Old Jan 13, 2008 | 10:20 AM
  #49
you can get a code READER for nothing from advanced,
^^check your coil packs and plugs make sure nothings arching
Old Jan 15, 2008 | 09:18 PM
  #50
SovXietday's Avatar
P1415
Manufacter Auxillary Emission Control
What the fawk is that?!
Old Jan 21, 2008 | 12:56 PM
  #51
mcochran1's Avatar
Got Codes: P0171 and P0174 and P0300 and P0507
Any ideas on how to fix them would be greatly appreciated.
Old Jan 22, 2008 | 10:06 PM
  #52
ill go through those both tomm...
Old Jan 28, 2008 | 01:07 PM
  #53
SlayerMaro's Avatar
Went to autozone today, and got a few codes. Three were generic, and related to my 02 sensors. The other one was P1134. I know it's GM specific, and I know it relates to emissions, but does anyone know what that is?
Old Jan 28, 2008 | 10:52 PM
  #54
it didnt have a name off the code reader?
Old Jan 30, 2008 | 10:28 PM
  #55
SlayerMaro's Avatar
No, it just gave a code.
Old Feb 3, 2008 | 01:03 AM
  #56
im pretty sure it has to do with the o2 sensor not switching fast enough, but i dont know the codes off hand...its either that or the its not heating up...either of which means probable bad o2
Old Feb 4, 2008 | 06:37 PM
  #57
SlayerMaro's Avatar
Hmm...that makes sense. My shop is going to be replacing my O2's while they install a bunch of other stuff. Hopefully they will fix it. Thanks a lot Jacob.
-John
Old Feb 20, 2008 | 11:59 AM
  #58
billyb's Avatar
Default code reader ?????????
hi went to auto zone and looked at 3 they had ???????? which is a good one does it half to be able to read the can code or ????? i read it some where help i'm so confused ?????? billyb.
Old May 18, 2008 | 03:09 PM
  #59
bmxer8699's Avatar
My car is throwing two codes, i replaced both of the 02 sensors at different times, i replaced the last first one in february and i replaced bank 1 2 days ago.
P0153 02 Sensor Circuit Slow Response (Bank 2 Sensor 1) this code
and this one P1153 Ho2s Insufficient switching bank 2 seonsor 1
what could this be since i replaced both 02 sensor recently
Old May 20, 2008 | 12:12 PM
  #60
check the wiring...or you could have just gotten a bad o2....they have free year replacement on them
