No Interiro Lights, and HVAC Controls
in the mirror, or the ones in the back of the hatch
98 Z
MY AC HVAC Controls Do not work either.. No Power... ( Won't blow
any air out)
What could be the problem? Fuse
Checked them.. They seem okay..
What other fuses?
I just diagnosed my failed courtesy lights using the factory service manual and it turned out to be the Body Control Module (BCM). But in my case, the glove-box and rearview mirror lights were working through their switches.
Have you installed any new stuff lately that could have caused a problem?
If you can't think of any potential problem areas, and you've found power at the fuses, the next step would be to see if there are any trouble codes stored in your BCM. It was really simple to do on my '99 (maybe it's the same for '98). I just turned the key to ON, back to OFF, then removed the Radio fuse. After that, I turned the key to ACC and back to OFF very quickly (the book said within one second). There were three audible tones, then the trouble codes flashed on one of the Warning lights (I can't remember which one). From there, you should follow the factory troubleshooting procedures, since it gets a little tricky. to diagnose this stuff when there's a BCM involved.
The Interior Lights Don't work, (Mirror Lights and Hatch Light)
, and the AC does not go on when you turn the ***** in the AC Panel.
Changed all Fuses to new ones, In the Fuse panel of the Dash ...
Are their
any fuses under the hood I should check for
