Sponsored by: CARiD
Squeak under hood!
Old Oct 24, 2006 | 09:46 PM
taintedmeat's Avatar
85 bucks? Those pullies are like 17 dollars at O'Rileys. Speaking of which, mine is squeaking again so I'll be picking one up in a couple of days myself.
Old Oct 24, 2006 | 10:13 PM
quadd224422's Avatar
Wow thanks for the response I called autozone and advanced out here but noone had it so I kinda got screwed into that 1 it sucks my fear is it may not be the idler pulley.Why would it get better and no noise after i replaced the belt then 200miles later it comes right back thats what I cant figure out so I might get screwed into a whole bunch of things I dont need so we'll see
are you sure that idler pulley is the same one im talking about next to the water pump and comes with the dust covers I believe if so I think ill take a raincheck on that and do it myself
thanks for the reply
goodluck with yours
quad
Old Oct 25, 2006 | 06:24 PM
Well I took my car in this morning to have the idler pulley installed it was only 15bucks he quoted my wrong.My problem is still their so now he said it is my crank pulley and it needs to be replaced I guess it has a slight wobble to it so he was going to order another stock 1 and i said no im going to upgrade.So now im going to order either the slp underdrive pulley or the asp underdrive pulley I havent made up my mind yet,and to top it all off someone smoked my tires on the car while it was their I didnt notice until about an hour ago cleaning it up since they dirtyed it up so now I cant take my car back to those ******.I think the guy may be b'sing me on the crank pulley to but i do see the slight wobble. Can anyone answer me why when I changed the belt it went away for 200miles?noone can answer that question.Also I can see the pulley wobble and cause it to slightly rub back and fourth on the new idler pulley so tomorrow I may go to speed inc and pick up the new crank pulley anyways and order the belts.Also does anyone know if the slp underdrive pulley and the asp one have the same belts so maybe I can order those ahead of time????
thanks guys for the help
quadd
Old Oct 26, 2006 | 12:57 AM
My crank pulley "wobbles" a bit also, but I always figured it was just because the whole engine itself is moving/vibrating a bit on the mounts since they're rubber, and that motion becomes apparent when focusing on the pulley.
Old Oct 26, 2006 | 06:36 AM
WU8's Avatar
WU8
quadd
Well I was planning to take mine in yesterday. But Tuesday I decided to take a look at the crank pulley as a last minute check. I pulled it most of the way off but had trouble pulling it all the way off the crank. Since it was getting late by then and I wanted to drive it in the next day, I just went ahead and put it back on. Drove it to work yesterday and heard nothing. Went to lunch, drove home, and went out last night...nothing. I don't know why it stopped and although I am expecting it to come back, I am keeping my fingers crossed. I'll let you know if it comes back.
Old Oct 26, 2006 | 09:19 PM
Hmmm maybe it does have something to do with the crank then im going to order the pulley tomorrow and have a good buddie of myne put it in since he was the puller for it.Hopfully it goes away im going to store my car soon but id like to atleast fix it beforeI do since I have things I need to do next spring.Myne does have a slight wobble to it but so does my buddies ss and its worse than myne so im not sure about it might be 250bucks wasted o well ill figure it out goodluck i hope it doesnt come back it sucks man
quad
Old Oct 26, 2006 | 09:33 PM
WU8's Avatar
WU8
quad
Yeah, thanks. Its still quiet so far. Like I said, if it comes back I'll give an update. Good luck with yours, please keep me informed.
Old Oct 27, 2006 | 03:13 PM
Well I picked up my slp underdrive pulley today and the belts so hopfully next week I will get it installed and see what happens.Im going to be very busy next week with work so i may not get it done until the end of the week plus I will sit their and wait for it im not gonna take the chance of having the ****** smoke my tires again.So I need to make in convinect for me i can sit their and wait and watch. So ill let you know what I come up with....
goodluck
quad
Old Oct 28, 2006 | 09:00 PM
Well I drove the car today i put miles on it with out a squeak and I havre not done anything so it.It just stopped for some reason so now im sitting here with my new slp underdrive pulley im still going to put it in but not yet ill wait to see if the squak actually stops.So now I have other probs with the brakes so tomorrow ill put in new pads and either cut the rotors and buy new ones whatever I need to do so i guess both of probs stopped for no reason really o well it goes like that sometimes
goodluck if it comes back
quad
Old Oct 29, 2006 | 02:03 PM
magnanpi's Avatar
i got the same problem...hope you can figure out what it is!
Old Oct 29, 2006 | 09:56 PM
Ya dude it sucks but myne stopped i drove it today and have a slight litle squeak almost cant hear it.I did change the idler pulley and it was real loud.Then I didnt drive it for about 4-5 days and it stopped.So now I have the underdrive pulley waiting to be installed maybe next weekend. I need to buy a crank pulley puller but I think it will be hard to install anyways not hard but **** 240ftpds of torque might be a problem with the limited room under their. we'll see but read what me and wu8 did it might help you maybe
goodluck man
quad
Old Oct 30, 2006 | 07:57 AM
  #32
WU8's Avatar
WU8
goodluck man
quad
If you have the car high enough, 240 ft lbs might not be too bad. I didnt have it all that high and it was a pain. So my advice is get it up in the air! Still no squeak here, but I'm waiting for the last test: rain.
