Sponsored by: CARiD
Squeak under hood!
Old Oct 14, 2006 | 12:25 PM
WU8's Avatar
WU8
Angry Squeak under hood!
Hey guys, lurker here. Ive been having trouble with a really annoying squeak under the hood. Yes, I've done a few searches on the board and I know everyone says to check the idler pulleys. Did that. Changed the tensioner and idler on the main belt, as well as the tensioner on the AC belt. Still squeaking. I got underneath and spun the alternator pulley, it had a squeak to it and I thought it was found. But after changing the alternator the car still squeaks. I know the crank pulley shouldnt squeak, which pretty much leaves the P/S pulley and water pump. The water pump itself is not leaking but could it be the squeaking anyway? Thanks in advance.
Old Oct 14, 2006 | 12:26 PM
taintedmeat's Avatar
There's an idler for the a/c belt as well you might look into. You could just try running it without the a/c belt at all and see if it goes away; then you'll know for sure.
Old Oct 14, 2006 | 12:29 PM
WU8's Avatar
WU8
Ah, Yea I should have mentioned I did try that and it was still there. So it's not the ac.
Old Oct 14, 2006 | 12:44 PM
Only leaves a couple of things man; either water pump or power steering pump. I don't think you'd get a squeak out of your a/c compressor, plus you said it still squeaked even with that belt off.
Fwiw, I had a water pump on my old Dodge truck go bad, and it never leaked once. It squealed loud as hell, I just figured it was a tensioner or something. Then I went in to look at it, and saw that my serp belt was chewed to ****. Then I grabbed the fan(motor was off), and noticed that it moved an inch back and forth in either direction. Water pump bearings were completely gone, and the weep hole had been filled with mud and gunk, preventing it from leaking to let me know the pump was on its way out.
Old Oct 14, 2006 | 01:23 PM
staringback05's Avatar
are you exactly sure its coming from the pulleys?.....if so...i might lean towards the PS pump actually, they actually love to have a little chirp everynow and then....i just replaced mine
Old Oct 14, 2006 | 02:18 PM
WU8's Avatar
WU8
Yea I was thinking the PS pump might be a possibilty, I was hoping not though because it looks like a pain in *** to change. By the way what does it cost?
It is kinda a chirping noise. It rarely does it at idle, and when it does its very brief and quiet. It really starts at about 1500 rpms and gets louder the higher I go. As I drive the car and it gets hot, it will sometimes quiet down a little and sometimes it will take more rpms to hear it.
I tried popping the hood and revving it up by hand and as it squeaked, I sprinkled a few drops of Armorall on the main belt. It shut it up immediately. I shut it down to take a break, started it up again after it cooled a bit and the squeak was back.
Old Oct 14, 2006 | 09:37 PM
quadd224422's Avatar
Hey i have a 98 ws6 with that same exact problem. first off I just bought the car and the guy who i got it from loved belt dressing.When i bought the car 3 weeks ago the belt squaled so bad i barly touched the gas it was that embaressing. Anyways i replaced the belt problem solved for the first 200 miles then it slowly came back the pulleys were still soaked with belt dressing and so was the new belt.So i pulled the soaked belt off cleaned all the pulleys and replaced it with a brand new 1. Well another 200miles came and so did the squeal again.Also my alternator pulley squeals a tiny bit when u turn it by hand.I dont think thats the problem however so now im going to just drive it and hope it slowly wears all out the best dressing that is.It just started again today, but its like you said a little chirp and sometimes it goes away. I did rev the motor up today as soon as I heard it and it went away for like 20 miles. So now like I said im jusst going to drive it maybe clean all the pulleys again and maybe see what happens. Sorry for the long post since i cant help you but just thought id let u know im having the same exact prob i hope you correct it as it is annoying goodluck man
quad
Old Oct 17, 2006 | 08:26 AM
WU8's Avatar
WU8
Thanks for the responses guys. And if anyone has anymore input please throw it in. I think I may get an asp or slp crank pulley/belt set just to eliminate another pulley possibility. At this point I only have the water pump, PS, and crank pulleys left to try. After that I'll have to take her in, which I really want to avoid. I can't imagine what the dealer would charge to track something like this down. But the sound is driving me to the point of wanting to blow a hole in the block.
Old Oct 17, 2006 | 10:25 PM
Ya kep us updated on that im very curious to see what you find out I was going to do the same thing with the pulleys your talkng about. Then i decided next week to take it in somewear and atleast find the problem it drives me nuts its more embarressing than anything so ill let you know what I find out. Im waiting for the rain to stop to get the car in and start troubleshooting i have a good mechanic in my town very honest guy so im going to let him check it out.
goodluck
quad
Old Oct 18, 2006 | 08:49 AM
A-Dub's Avatar
The crank pulley has no bearings, not possible for it to squeak.
Old Oct 18, 2006 | 09:37 AM
WU8's Avatar
WU8
I understand that. But it was just one more thing to try. I was thinking of getting an asp or slp underdrive anyway. By the way, does it use a keyway? Is it possible that the pulley could slip?
Old Oct 18, 2006 | 10:23 AM
A-Dub's Avatar
If you want to try and dump money into something that can't squeak and run into all the false knock issues that come with underdrive pulleys, have at it.
The crank pulley is an interference fit, no key way. Its not slipping. Its also possible the squeak isn't coming from your serpentine system....if you remove the belts and run the engine, is the noise still there. Have you replaced the belt yet?
Old Oct 18, 2006 | 11:29 AM
WU8's Avatar
WU8
I replaced the belts before I started messing with the pulleys. I also tried running it with no belts and the sound was gone. That pretty much leaves the PS and water pump. Is there any way to check without changing them?
Old Oct 18, 2006 | 11:33 AM
A-Dub's Avatar
use a mechanics scope and listen. You can rig up something with a wrench or screwdriver. Remove the belts spin each device individually and listen
Old Oct 18, 2006 | 09:50 PM
I think mine is definetly the water pump. But why would changing a belt stop that for roughly 200 miles then slowly start up again? It sounds like its coming right from the water pump I drove it today for about 10 miles and wow its getting very loud it doesnt do it at idle when the sec u step it up a few hundred rpms it starts and only gets louder the more you rev it.So im pretty much stumped. I think this weekend ill try to get it to someone my cars almost done for the year so i was thinking about letting it go till next year but man the last few weeks will be very annoying. The only thing i cant figure out is why it started 200 miles after a new beltis it possible the belt loosend up and now is very slightly slipping i wouldent think so but i dont know??
thanks for all the help guys
goodluck with that
quad
Old Oct 18, 2006 | 10:37 PM
WU8's Avatar
WU8
goodluck with that
quad
Thanks for the update. I am stumped as well. Played with it again today. I took off the main belt and started it up, squeaked like normal. So I was thinking the first time I tried this it was a fluke. Tried lubing the idler on the AC belt but that didnt work. Perhaps its the clutch in the AC compressor. Took off the main belt next and tried it again without any belts. Once again no sound. Put back on the main and took it for a drive without the AC belt and it was back to squeaking again. Rather frustrating at this point. So without either belt, although I havent driven it, its slient. And with either one belt or the other it squeaks.
On a side note, when I only had the AC belt on, I tried turing on the AC. The squeak quieted for just a sec and then came right back.
Old Oct 22, 2006 | 10:38 PM
Hey wu8 just wondering if you solved the problem or not? Im taking my car in tomorrow to get it fixed i cant even begin to guess anymore without swapping all kinds of pulleys so before I go and do that im going to let a guy in my town look at he has a good reputation so we'll see what happens ill let you know what we find out here hopfully nothing serious goodluck man
quad
Old Oct 23, 2006 | 10:24 AM
WU8's Avatar
WU8
quad
I haven't had any luck yet. I know a service manager at a local Pontiac dealership and I finally had the time to bring it to him while he was there. He suggested to change the water pump. I had my doubts and I was right. I changed the water pump over the weekend but had no luck.
He also had another suggestion, which turned out not to be it, but it was something simple to check. There's a piece of vacuum line in front of the intake manifold that can get soft and crack. When it cracks it will suck in air and sound similar to a belt problem. I can get a pic of it for you later if you want (I'm at work now). Please let me know if you find anything when you take it in. Mine will probably go in when I can make it to and from the dealership.
Old Oct 23, 2006 | 01:16 PM
Ya i thought myne might be a water pump also, but after i cleaned all the pulleys and replaced the main belt it came back after 200miles so thats what im stumped at I have an appointment tomorrow morning to take the car in and hopfully it will be an easy prob for them but who knows so ill let you know. I also pulled off my a/c belt and it still made the noise so its not that so hopfully it can be easily diagnosed without costing an arm and a leg so ill let you know what i find out tomorrow.also lastnight I pulled the belt off again and cleaned everything and it made the noise way worse so it might be a loose pulley but they all seem tight so I cant guess anymore ill keep you updated goodluck
quad
Old Oct 24, 2006 | 07:27 PM
Well I took the car in this morning it has to go back tomorrow but their was a service bulliton about my year 97-9 ls1s the idler pulleys dustshield is bad and causes a bearing to slowly wear out. Even though that doesnt explain why after Ii changed the main belt the noise stopped for 200 miles he couldent answer that either so im skeptical so the part will be in tomrrow morning or late tonight so it was 85bucks so ill see what happens and ill let you know tomrrow if it works or not im out of options now so I think this might be the prob i hope so anyways goodluck
quad
