Ngk Tr55 Vs Otherd
My 2001 Ss Came With Denso Ptj16r15. I Think They Are The Double
Platnum.at Approx. 30000 Miles I Switched To The Tr55's.although I
Never Dynoed The Car With The Tr's, I Never Felt They Were As Good As The Denso's. At This Point Approx.65000 Miles The Original Plugs Look Better Then The Tr's. A Long Way To Get To My Question.
Does Any One Have Any True Data Or Empirical Proof That The Tr's Are Better? Or Is It They Are Cheap Which Seems To Be The Biggest Response. I'm Changing Them This Weekend. At This Point I'm Leaning To Denso Again.
Sorry About The Long Post And The Capitols
The issue with the platinum plugs is that the ring blows off quickly at high RPM. This makes them no better than a standard plug and there is now a little platinum ring that need to float through the engine.
And if you're interested in "proving" anything I just said, go price some plugs.
They Werent Iridiums.
What I Wanted And Sill Want But Doesn't Seem To Be Available Is The
Following.
Empirical Proof That The Tr55's Are Better.
You Seemed To Prove My Point By Mentioning Money As The Main Reason To Purchase Ngk's.
Show ne ANY plug with emperical proof that ir is better than any other. They are maintenance items like washer fluid if ya ask me.
And Other Forums.
I Only Wanted To Know If Any One Had Done Testing Of One Against
The Other. As It Happens I Did'nt Think So. That Doesnt Mean I Wanted
To Be Correct. I Was Hoping To Learn And Be Informed. Not Here Not Now I Guess.
By The Way The Spelling Is Empirical
Again, throwing about a 1.50 each in the trash, after I look at them, is a lot easier than 5.00+.
And, yeah there is a lot of heard mentality on the internet. Ultimately it's up to you as to what you use for plugs, NGKs are cheap and easy to get.
Nuff said? Good luck with whatever you use.
Following.
And Other Forums.
As for your question, I've logged fewer misfires on a-tap (my scanner) using NGK TR55s gapped at .055" than the stock platinum plugs. That's the only proof I have.
i also decided to put the original wires back on.i took off the msd 8.5's.
rpmws6 did the capitols really bother you that much? i apoligized about them in
my first post. again i was looking for test results not opinions! you act like wanting
proof or test results is a bad thing.
Running misfire logs (with a-tap), the stock platinums produced more random misfires than the NGK TR55s, all else being equal (even as the NGKs aged, they still ran better). However, I have not tested the ac delco iridiums.
Not sure what else to tell you. I can't speak about a direct dyno comparison, but that doesn't make the results any less valid......
