Just finished replacing headlight gear
I'm pretty sure I did everything right, I just remember people saying bend the 3 tabs back, or you'll mess the gear up. I didn't see any tabs to bend back? I just hope my epoxy job stays together, well see tomm when I go to use them. I would hate to pull this apart again, my right hand is beat up from squeezing it through the bumper and highbeam light!
Mark Jr.
Mark Jr.
good luck
Mark Jr.
-First of when you drive with the affected headlight up does it vibrate any at all or is it rather solid in place? If there is any vibration issues you need to take it all the way back down to having the lever arm off the motor part. Then crank it onto the other side of the guide tabs, those things with tabs. It needs to make the LONG way around on the outside of those. NOT on the inside. Watch the other light go up and down several times (watching that arm) and then watch what you did. (You need extra hands for this) This was what I did wrong the first time.
-If the headlamp housing unit does not vibrate while you have the light up then you should try checking the gap that you have with the light in the up position from the tab. Do not let there be a gap, but dont crank it down hard. You still only got a plastic gear in there.
-Do not forget that you can adjust the headlamp metal bezel cover, maybe find a happy middle ground, however the first 2 should get ya fixed.
On a side note took me 4 hours and some scraped hands to finally get mine right, but man is it worth not hearing that girrrrrrrrrddddd sound again. I am not sure as to the root cause (asides from plastic) but you might try not turning on the headlamps while your moving at high speeds, that must generate quite a drag. Like holding a 3 ring binder outside your window at that speed.
Blackduk98 you said you finally broke down and bought a new motor for 101? Will that solve all my problems? If I get a new motor, which obviously has a new gear in it, I won't have to worry about bending any tabs back or epoxying anything right? Just disconnect the old one, put in the new one and go? Nothing hard about that right? I am not sure if my problem is the gear cover came loose or I didn't install the motor right? But the headlight works fine, just grinds on it's way up. It took a few days for it to start doing that, so the cover must be coming off, damn it! I need to get back into a corvette, C6 fixed headlights or a C5 with the C5R lights, this sucks!
Mark Jr.
Mark Jr.
