heat isn't working
Thanks for the help.
The vacuum operated diverter flaps inside the air box
have to steer airflow through the heater core. If these
are stuck or you lost vacuum then maybe no heat,
depending on where it got stuck. Might tear into the
climate control, check the backside of the control and
see if there's vacuum in (engine running) etc. If you
switch the mode **** and listen carefully you should
hear little hisses and clunks under the dash as it moves
the flaps around.
