Sponsored by: CARiD
Window Question
Old Dec 6, 2006 | 06:32 PM
Nemo02Z's Avatar
Default Window Question
Can someone tell me if its my window motor or the window switch. When I bring down my window all the way and try to bring it back up the window does not want to come up, I have to play with the switch and then it will come up....Its an 02Z...
Old Dec 6, 2006 | 06:47 PM
2001NBMZ28's Avatar
If you wait a couple minutes, then it moves up a little and stops, wait longer then moves up a little further than before, etc. sounds like the motor. Welcome to the club.
Old Dec 6, 2006 | 06:58 PM
SoCalZ28's Avatar
im looking at doing this mod the next time i have to replace my window motors
http://www.autotrix.net/
Old Dec 6, 2006 | 08:15 PM
2002_B4C's Avatar
It is the motor. Have fun changing that bitch! lol. It's not too bad. there are many good threads with the info. Good luck!
Old Dec 6, 2006 | 09:21 PM
zach_ws6's Avatar
as long as you find the link on here that shows where to drill your holes, its easy as hell
Old Dec 6, 2006 | 09:22 PM
Nemo02Z's Avatar
No it goes down then it does not come out at all until I b$tch slap the button then it goes all the way up.... I guess I 'll keep bringing it down about 3/4 of the way and be happy with that till it starts doing something else...
Old Dec 7, 2006 | 01:18 AM
autotrix's Avatar
Closed ex-Sponsor Account
This sounds like A. The new motor is kinda crappy and once it heats up and the resistance increases it does not have enough windings in the motor to keep the push up. B. Your tracks and or something like guides in the door should be greased and it just slows down because it gets hard to move the window at the top. C. Or you just have the normal voltage drop the passenger side normally gets.
Check out this link https://ls1tech.com/forums/lsx-parts-sale/609435-slow-passenger-window-check-out.html
Old Dec 7, 2006 | 05:42 PM
Nemo02Z's Avatar
Check out this link https://ls1tech.com/forums/showthread.php?t=609435
Thanks this info is great when my passenger window gets like that i will order the kit... but its my drivers side window I guess for now ill pull the door panel off and grease the tracks and see if that helps.... thanks for the info
Old Dec 9, 2006 | 05:52 PM
autotrix's Avatar
Good to hear!
Please post about your expirence afterwards!
