Sponsored by: CARiD
New 1LE mount and still problem(clunking)
Old Dec 12, 2006 | 08:57 PM
98camaroLS1M6's Avatar
Default New 1LE mount and still problem(clunking)
I have a clunk under hard shifting and replaced the trans mount with stock 1LE the old was indeed torn, this helped but there is still a clunk and when I accelerate the shifter will rise about a half inch but this seems normal. My torque arm is tight, I don't know what else could be moving to create this? Could it be a bad motor mount, it sounds like transmount/TA problem but I checked everything and it seems tight. Should I try a poly mount? Could it be output shaft play or Driveshaft or something? thanks.
Old Dec 12, 2006 | 10:37 PM
orangeapeel's Avatar
ЯєŧąяĐ Єl¡m¡иąŧøя ™
Mine clunked too. I think that is just the way it is. I have solid mounts now.
Old Dec 12, 2006 | 10:44 PM
Do you think poly (prothane) trans mount would help?
Old Dec 13, 2006 | 10:07 AM
anyone else? opinions?
Old Dec 13, 2006 | 10:14 AM
JDJP's Avatar
What exhaust do you have?
ORYs will bump the bottom of the car.
Old Dec 13, 2006 | 10:29 AM
Fulton 1's Avatar
Best way I have found to combat the clunking problem is by installed a single poly engine mount on the driver's side. In my experience this is an order of magnitude more effective than messing with the trans mount.
You will get 90-95% of the benefit of doing both mounts by doing just the driver's side alone and you will save yourself some work. Go with the Prothane bushings - they are a direct fit. Last time I checked (which has admittedly been a while) the Energy Suspension pieces were not direct fit and required some slight shimming.
Install is a bit of a PITA, but well worth the effort. There are some decent install guides floating around as well...
Old Dec 13, 2006 | 03:16 PM
Sneakyws6's Avatar
On the tree
I noticed while under my car the other day I think if the tranny moves any amount even slightly it is the shifter area of the tranny hitting the opening.
Old Dec 15, 2006 | 04:42 AM
98RedZone's Avatar
I changed my tq arm and trans mount to energy suspension poly's and my clunking went away.
Old Dec 15, 2006 | 10:04 AM
Sneakyws6's Avatar
On the tree
Ok so does anyone have the part number for the Energy Suspension Trans mount and the the Energy Suspension torque arm mount?
I looked on ES site and they dont even list a trans mount and dont have a torque arm mount even listed.
Old Dec 16, 2006 | 06:46 PM
2002ws-6's Avatar
Bought mine from thunder racing ------------------------------>>>>>>
