Turn Signal lever sucks
This is just a dumb annoying problem, when I want to flick the lever down to make a left turn the lever dosent want to "click" I have to press kind of hard to make it click. When I make the turn it does "unclick" just as it should.
Like I said its just an annoying problem, but does anybody know a fix?
new spring inside, its a pita(or so i have been told) it happened on my 89 ciera, we ended up flicking the indicator down/to the middle to "simulate" an indicator....we shoulda probably got it fixed
![The Judge](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_judge.gif)
Hmm how do you go about fixing it, do you have to take the steering wheel off? if so then Ill probably just let it be.
