Pull which ABS fuse to properly disable ABS?
So which fuse or fuses? I see two of the larger are labeled ABS SOL but that seems like it would be the noids that the ABS module is driving... So which fuse to properly disable it? And correct me if I'm wrong, but this will disable TCS too as well, since they are dependent, right?
will this stop TCS from being totally active? Do I need to pull it's fuses as well? What if I leave ABS and pull all of the TCS fuses? Thanks guys.
EDIT: I messed up on negation. meant to say weren't not were.
hell i drive with 1/32 tread on my g-force's in the rain with a 3600 converter im just careful
