Sponsored by: CARiD
Lights Pulsating..
Old Jan 8, 2007 | 02:07 AM
01WSix's Avatar
Question Lights Pulsating..
If anyone can help me out,When ever i start my 2001 Ta the headlights and the gauges pulsate really bad. .also while i'm driving and push in my clutch,my volts gauge goes around 10 volts,and goes right back up to normal volts,at the same time my lights go dime,then back normal..I just read on the some page that a coil could be bad??Is this true or could it be the Alt.?Any help??
Old Jan 8, 2007 | 12:19 PM
fortworthr6's Avatar
WOW I have the exact same problem except for the gauge moving. I would really like to know also.
Old Jan 8, 2007 | 05:17 PM
fatboyq's Avatar
remove your battery terminals and clean them real good with a wire brush and a can of coke, pepsi no joke. I bet there is allot of corrosion built up on the terminals. It did wonders for my car. dont forget to apply some dielectic grease after your done.
Old Jan 8, 2007 | 10:07 PM
01WSix's Avatar
I also noticed that when i'm driving at low rpms(55 in 6th or running 50 in 5th)My car feels like its missing just alittle???I'll try cleaning my terminals but they are real clean.....
Old Jan 8, 2007 | 10:16 PM
Silas2k's Avatar
u might also want to check the ponytail wire in the back on the alternator, sometimes if ur power steering pump is leaking a little it will dissolve the rubber piece that seals the water out of the connection to the alternator... so if u get water in there itll stay for a while and mess with ur volts
Old Jan 9, 2007 | 06:02 PM
Flawless02SS's Avatar
My lights pulsate too. My battery cables are Super clean and I have NO power steering leaks. Does anyone have a clue what causes this. My volt hands always read good, light just pulsating.
Old Jan 9, 2007 | 06:30 PM
stroked383z's Avatar
probably the alternator, it's got a voltage regulator in it and sometimes it goes bad. IMO
Old Jan 9, 2007 | 06:59 PM
chaman's Avatar
Almost always is a faulty alternator. When this happened it also resulted to be my battery. I had an Optima Red Top at the time. It became damaged when it drained out. I know have a Yellow Top.
Old Jan 10, 2007 | 12:08 AM
Philhawk02's Avatar
I had this start happening after having to jump start the 7 year old factory battery, which died after being driven all day and shut off for 20 minutes, and driving it home basically running completely on the alternator. I have a feeling the alternator overheats and fries the regulator. I haven't had to replace it yet, but its not going to be a shock like waking up with your head sewn to the carpet when I do have to replace it.
I used to go through an alternator every 10 to 12 months in a turbo 3.1 I had...I know the heat under the hood just cooked it in that amount of time.
Old Jan 11, 2007 | 02:45 PM
zfastss's Avatar
I have the EXACT same problem I noticed it only after I replaced my dead stock delco battery with an Optima Red top. Only 30k on the clock too. I'm leaning towards the voltage regulator being fried. I too had to jump start my car before the Optima and was probably running on the alternator only.
Old Jan 11, 2007 | 10:48 PM
So should I replace the alternator or just ride it out until it dies completly?
Old Jan 11, 2007 | 10:54 PM
chaman's Avatar
Check them both, alternator and battery. Be sure of whats wrong before changing anything. You could very well be looking at a combination of a faulty alternator and failing battery.
Old Jan 11, 2007 | 10:58 PM
True, battery is new though, new Red Top. Its about a year old maybe.
Old Jan 12, 2007 | 12:42 AM
CULATR's Avatar
i went thru 2 new red top's before i got a good one so watch out on a garage car that i crunk up every weekend
Old Jan 14, 2007 | 02:02 AM
Grimes's Avatar
+1 on the alternator. One of the diodes in the regulator probably blew.
Old Jan 14, 2007 | 12:19 PM
thecarolinakid~98ss's Avatar
I had started a thread earlier about this or a similar situation I am having. I notice that when at night when sitting at a light my headlights will go dim then back to normal. My car has always done this. I have changed the battery once so its fairly new.
Old Jan 14, 2007 | 01:25 PM
blk97z28's Avatar
on my car it did that exact same thing but i was just a lose battery connection i would check all battery cables and test the battery to see if it not staying charged and if not then it is your alenator!
Old Jan 14, 2007 | 06:04 PM
chaman's Avatar
Also while you are at it make sure all ground connections are fine.
Old Jan 16, 2007 | 05:24 PM
I think I will try the alternator, I can get parts very cheap from GM, so it won't cost me much at all. Thanks guys!!
Old Jan 17, 2007 | 11:41 AM
Hawk108's Avatar
yea ive got tha same problem and also have a new battery.....i guess ill replace the alternator soon....
