Car gets very hot at a stop, but very cool while going
Is it possibly my waterpump for the radiator system? That is my ultimate guess. The fact is, the car runs VERY cool when im driving, even at low speeds. But when I stop at a stop light, the thermostat goes up after sittin for a few min. Never higher than the half way point of 210 (I think thats the half way point) anyway, it goes up high enough to kick the fans on, but regardless, the car should not heat up that high. It didnt use to do that. So something is up.
The fans are not programmed to turn on until somewhere around 240 degrees so it is not getting hot. With the a/c off and sitting in traffic it will warm up bc there is no airflow across the condensor and radiator until the pcm commands the fans.
well the thing is I recently had some problems with a hose that blew off and blew out all the fluid, I was doing some trial and error tests trying to fix a few things, build a new hose and some other things, so I've had to replace the fluid completely a few times, so I know for a fact the fluid isnt bad. And I've checked the air bubbles thing several times, no air comes out. So its not that either...and as for the thermostat, i just replaced that about a month or so ago...whenever I was doing some trial and errors, so its not that either....what was the comment about someone said my cap might be bad? because whenever the car starts to get hot in idle, i start to smell fluid, is it possible the lids go bad? the pressure cap? i never thought of that...and i duno, its either that or the waterpump....i just think its something because car use to never do that before, so its not normal, that i kno...
first thing you need to do is go under the car and look to see whats jammed in the radiator. on my camaro i was doing the oil change and in the front of the radiator there was a black garbage bag and leaves and paper sucked up in it. i pulled it all out and now the car runs alot cooler. another thing check to make sure both fans are working. both my old 95 and 97 had a fan go out which make it do the same as your. also flush the radiator. but remmeber to bleed the lines. goodluck!
