2000ss Window Motor problem?
http://shbox.com/page/windowmotor.html
Good luck and just take your time.
You save a shitton of money doing it yourself. I did it a few years ago on my Z34 and it cut my hands up pretty bad but only cost me like $60. Pull the old motor out using the guide form Shoebox (linked above) and remove the thermal cut-out (bypass it).
I can take no credit for being smart enough to find the thermal circuit, I just found the discussions here:
Bypass instructions #1
Bypass instructions #2
Not really hard, just be sure you have a soldering iron and some self-tapping screws, nuts and bolts or maybe even a pop-rivet gun for putting everything back together.
As far as the thermal by-pass; I feel as if the thermal proxy switch is there for a reason, a safety precaution, so you wont cut someones fingers off by accident!
