Sponsored by: CARiD
Oil in coolant? HELP!!!
Old Mar 25, 2007 | 05:49 PM
6SSPEED's Avatar
Default Oil in coolant? HELP!!!
My buddy has a 2002 B4C LS1 camaro with 105k miles. He pulled off the radiator cap to check the coolant and noticed oil bubbles at the surface of the coolant in the radiator.What does this mean? Any help would be appreciated.
BTW: It doesn't smoke, knock, or tick any.
Old Mar 25, 2007 | 06:20 PM
nickls1's Avatar
sounds like a head gasket problem i think
Old Mar 25, 2007 | 06:43 PM
Shinigami2x4's Avatar
might be the start of a bad head gasket, try doing a coolent flush (a good one) and see what happens. Also do an oil change and see if any coolent made it to the oil If so your headgasket is gone or broken off (in the corners mainly)
Old Mar 25, 2007 | 07:12 PM
Jeremiah's Avatar
Its normal from my experience to have an oil like sludge at the radiator cap on any high millage car that has not been properly maintained/flushed ect.
Old Mar 25, 2007 | 07:18 PM
warp10's Avatar
Does he have a power steering oil cooler?
Old Mar 25, 2007 | 10:15 PM
autotrix's Avatar
Closed ex-Sponsor Account
Yeah, check all your fluid levels and conditions to try and pinpoint which type of oil is mixing with your coolant.
Old Mar 25, 2007 | 10:23 PM
01WS6/tamu's Avatar
If its an auto the trans cooler may be leaking internally
Old Mar 25, 2007 | 11:01 PM
sobaka79's Avatar
it could just be built up gunk from way too old coolant...
Old Mar 25, 2007 | 11:02 PM
joshp14's Avatar
I'd say either the P/S cooler or trans cooler in the radiator. I'm guessing since its a B4C car it will have both the p/s cooler and auto trans. Trans or p/s fluid low?
Old Mar 25, 2007 | 11:10 PM
EDS01SS's Avatar
yup another vote for P/S or tranny cooler. does he have to fill the P/S pump often?
Old Mar 26, 2007 | 11:45 AM
skifast87's Avatar
milkshakes in the crank case?
Old Mar 26, 2007 | 08:08 PM
6SSPEED's Avatar
No oil in the crankcase. He thinks he narrowed it down to the power steering cooler. Thanks for all the help.
Old Mar 26, 2007 | 08:12 PM
autotrix's Avatar
You came to the right place!
Old Mar 28, 2007 | 06:01 AM
pjb's Avatar
pjb
my PS cooler failed and leaked PS fluid into the cooling system. The oily build up will also cause the low coolant light to come on. Test by getting a radiator pressure tester (free from autozone). When you pressurize the radiator you will see bubbles in the PS resevoir. Replace the PS cooler, clean the low coolant sensor, flush the cooling and PS systems, and you will be good.
