Sponsored by: CARiD
Mirror lights will not turn off
Old Mar 31, 2007 | 12:11 PM
98ZCONVERT's Avatar
Default Mirror lights will not turn off
The mirror lights on my 98 Z28 Convertible will not turn off. It is not the dimmer swith being all the way up. Normally these lights come on when you open a door and go off when you close the door or put the key in the ignition. I have made sure the doors are closed but the lights will not turn off anymore. Is there a switch in the door? If there is a switch, where the heck is located? I can't find a switch or button in the door like there used to be in the old days.
Got any ideas. It is hard to drive at night with these lights on.
Old Mar 31, 2007 | 03:26 PM
johnnybravo's Avatar
Isn't there a switch on the bottom front on either side of the mirror?
Old Mar 31, 2007 | 03:37 PM
Shinigami2x4's Avatar
Is any part of your vehical loose like are the doors shut all the way, the hatch shut all the way? is your VATS working right?
Old Apr 13, 2007 | 01:22 PM
98ZCONVERT's Avatar
Actually, all of the interior lights (courtesy lights) stay on. I think that the trunk interior light stays on as well. It's not the door being partially open and it sure as heck is not just the switch for the map lights being on.
Old Apr 13, 2007 | 01:36 PM
Weezzer's Avatar
It could be the door position sensor that is just above the latching mechanism inside the door. There is a little plastic gear that meshes with the door latch that lets the computer know when the door is open or closed. It could have crapped out on you. Mine was just the opposit, my car always thought my door was closed. The hatch release woudln't work unless I had the other door open. The power door locks wouldn't activate from that side because the computer never registered the door had been opened after the alarm had been deactivated... interior lights woudln't come on... etc...
Its worth a look see, replacement part is $40 from auto crap - couple hundred from the dealer....
Old Apr 24, 2007 | 08:21 AM
98ZCONVERT's Avatar
I feel like I now own a part of the space shuttle. Jim Reed Chevrolet (Nashville) replaced the BCM...get this...the Body Control Module. It only cost $555. Really glad it was not something as simple as a door swith. lol
Old Apr 24, 2007 | 09:10 AM
taintedmeat's Avatar
Only $555? Glad it was something cheap
