Oil Leak Questions
Oil Leak Questions
I have been on here recently regarding an oil leak thats depositing oil on the rear of my oil pan. To combat this, I was under the car today to see what needs to be replaced. I was afraid of the rear main seal leaking, so I popped the converter access hole open on the bellhousing to see if there was any oil in there, it was bone dry. If I am correct, this means that there is no rear main seal leak, because if there was wouldnt the flywheel and converter be covered with oil? It appears that there is oil running down the side of my block due to what looks like a valve cover issue. The PCV valve was just changed, but was caked with deposits but still clicked when shaken indicating that it still worked.
I have included a few pictures where there is some oil build up on the drivers side rear underside of the engine. From the pics, we can see the oil filter which is tight and has a good seal on it, but what is that weird looking sensor/valve thing above the filter assembly? Does the gasket on that go bad? There is a significant amount of oil build up around there. Please help me regarding the rear main seal info and that sensor/valve above the oil filter. Thanks.
