Normal setup: A vaccuum line will go to a diaphram. The diaphram does the physical work of moving the door to the proper setting, windshield, dash outlets, under dash (on the legs). The diaphram is controlled by your in-dash switch. Possible failures are the vaccuum line, the diaphram, or the switch (in that order). You cannot hear a vaccuum leak, it is too quiet when the engine is running. You could put a vaccuum gauge on it and see how quickly it leaks down. You can follow the lines and look for a split. You can simulate by pulling a vaccuum on the diaphram. Mainly, it is parts replacement until it works. Again, I would go in the order mentioned, line, diaphram, then switch.
